求助一个dspic33fj128mc706的AD采样问题~大神帮忙解决一下啊 ~
 楼主| lam2083 发表于 2012-10-18 20:38 | 显示全部楼层 |阅读模式
也不算问题了,就是自己想不明白,想问问为什么,我用dspic33fj128mc706
进行AD采样,扫描采样方式,由于懒得用DMA,就直接进中断读buf来存数。实验时候采用的是2通道扫描, 我对AD的各个寄存器采用了如下设置
void initadc1()
    AD1CON1bits.FORM   = 0;
           // Data Output Format: Signed Fraction (Q15 format)
   AD1CON1bits.SSRC   = 0;  // Sample human
   AD1CON1bits.ASAM   = 0;
// ADC Sample Control: Sampling begins immediately after conversion
  AD1CON1bits.AD12B  = 0;  // 10-bit ADC operation
  AD1CON2bits.CSCNA = 1;
                 // Scan Input Selections for CH0+ during Sample A bit
  AD1CON2bits.CHPS  = 0;  // Converts CH0
  AD1CON3bits.ADRC = 0;  // ADC Clock is derived from Systems Clock
  AD1CON3bits.ADCS = 63;
  AD1CON2bits.SMPI    = 1; // 4 ADC Channel is scanned
  AD1CSSLbits.CSS4=1;   // Enable AN4 for channel scan
  AD1CSSLbits.CSS5=1;
                                    // Enable AN5 for channel scan
  AD1PCFGL=0xFFFF;
   AD1PCFGLbits.PCFG4 = 0;  // AN4 as Analog Input
  AD1PCFGLbits.PCFG5 = 0;  // AN5 as Analog Input
        IFS0bits.AD1IF = 0;   // Clear the A/D interrupt flag bit
        IEC0bits.AD1IE = 1;   // Enable A/D interrupt
设置采用的是两通道的输入扫描,分别是AN4和AN5,按照手册上说,是每完成两个采用,产生一次中断。可是buf是会被覆盖的啊,按道理说我在中断程序中只能读到采到的一个值,为什么我确实读到了两个呢?究竟是怎么实现的 ?请大神给解答一下~谢啦!!
