自己做的pcb板。用stc12c5a60s2 I/O口推挽输出。采用电阻分压。
SD卡套上用电表测量3.3v电平正确。
但是读出的数据总是0xff
- unsigned char SD_spi_read(void)
- UART_Send_Str("b");//测试用
- SD_SO = 1;
- SD_SCL = 1;
- if (is_init) delay(DELAY_TIME);
- SD_SCL = 0;
- _dat7 = SD_SO;
- SD_SCL = 1;
- SD_SCL = 0;
- _dat6 = SD_SO;
- SD_SCL = 1;
- SD_SCL = 0;
- _dat5 = SD_SO;
- SD_SCL = 1;
- SD_SCL = 0;
- _dat4 = SD_SO;
- SD_SCL = 1;
- SD_SCL = 0;
- _dat3 = SD_SO;
- SD_SCL = 1;
- SD_SCL = 0;
- _dat2 = SD_SO;
- SD_SCL = 1;
- SD_SCL = 0;
- _dat1 = SD_SO;
- SD_SCL = 1;
- SD_SCL = 0;
- _dat0 = SD_SO;
- UART_Send_Byte(_dat);//通过串口查看总是0xFF
- return _dat;
