STM32 usbOTG
1686|0
 楼主| wangjun2012 发表于 2012-11-26 13:02 | 显示全部楼层 |阅读模式
USB_OTG_Status OTGD_FS_WritePacket(uint8_t *src, uint8_t ch_ep_num, uint16_t bytes)
  USB_OTG_Status status = USB_OTG_OK;
  uint32_t dword_count , i;
  __IO uint32_t *fifo;
  /* Find the DWORD length, padded by extra bytes as neccessary if MPS
   * is not a multiple of DWORD */
  dword_count =  (bytes + 3) / 4;
  fifo = core_regs.data_fifo[ch_ep_num];
  for (i = 0; i < dword_count; i++, src += 4)
    WRITE_REG32( fifo, *((__packed uint32_t *)src) );
  return status;
执行以上函数,PC读取数据失败,会是什么原因造成的?
