#include <iom16v.h> #include <macros.h> #pragma interrupt_handler gs:9 #pragma interrupt_handler sd:10 #define LCM_RS_1 PORTB|=(1<<7) #define LCM_RS_0 PORTB&=(~(1<<7)) #define LCM_RW_1 PORTB|=(1<<6) #define LCM_RW_0 PORTB&=(~(1<<6)) #define LCM_E_1 PORTB|=(1<<5) #define LCM_E_0 PORTB&=(~(1<<5)) #define uint unsigned int #define uchar unsigned char uint num=5;/*用以计个数*/ const unsigned char LCM_Dis_String1[]="number:"; const unsigned char LCM_Dis_String2[]="speed:"; const unsigned char table[]="0123456789"; void delay_1(uint ms) { uint i,j; for(i=0;i<ms;i++) for(j=0;j<1141;j++); } void delay_2(uint ns) { uint k,h; for(k=0;k<ns;k++) for(h=0;h<8;h++); } unsigned char LCM_Re_BAC() { unsigned char status; DDRA=0X00; LCM_RS_0; LCM_RW_1; LCM_E_1; delay_2(1000); status=PINA; LCM_E_0; return status; } void LCM_Wr_CMD(uchar cmd_dat) { while(LCM_Re_BAC()>=0X80); DDRA=0XFF; LCM_RS_0; LCM_RW_0; LCM_E_1; PORTA=cmd_dat; delay_2(1000); LCM_E_0; } void LCM_Wr_DAT(uchar dis_dat) { while(LCM_Re_BAC()>=0X80); DDRA=0XFF; LCM_RS_1; LCM_RW_0; LCM_E_1; PORTA=dis_dat; delay_2(1000); LCM_E_0; delay_2(400); } void LCM_1602_Init(void) { LCM_Wr_CMD(0X38); delay_1(5); LCM_Wr_CMD(0X0c); delay_1(5); LCM_Wr_CMD(0X06); delay_1(5); LCM_Wr_CMD(0X01); delay_1(5); } void gs(void) /*定时器1用以计算脉冲个数*/ { uint a=0,b=0,c=0,d=0,e=0,f=0,g=0; TCCR1B=0X00; SREG|=BIT(7); TIMSK&=0XFB; if (num<999) { LCM_Wr_CMD(0X80+0X0D); LCM_Wr_DAT('g'); a=num/100; d=num%100; b=d/10; c=d%10; LCM_Wr_CMD(0X80+0X0A); delay_2(10); LCM_Wr_DAT(table[a]); delay_2(10); LCM_Wr_DAT(table[b]); delay_2(10); LCM_Wr_DAT(table[c]); delay_2(10); } else { LCM_Wr_CMD(0X80+0X0D); LCM_Wr_DAT('k'); LCM_Wr_DAT('g'); a=num/100000; d=num%100000; b=d/10000; e=d%10000; c=e/1000; f=e%1000; g=f/100; LCM_Wr_CMD(0X80+0X0A); if((!a)&(!b)) { LCM_Wr_DAT(table[c]); delay_2(10); LCM_Wr_DAT('.'); delay_2(10); LCM_Wr_DAT(table[g]); delay_2(10); } else { LCM_Wr_DAT(table[c]); LCM_Wr_DAT('.'); LCM_Wr_DAT(table[g]); } } TCNT1H=0XF0; TCNT1L=0XBE; TIMSK|=BIT(2); TCCR1B=0X04; } void sd(void) /*定时器0用以就算传输速度,假定定时是1s*/ { uint a=num; TCCR0=0; TIMSK=0XFE; LCM_Wr_CMD(0XC0+0X08); LCM_Wr_DAT(table[a]); TCNT0=0X01; TIMSK|=BIT(0); TCCR0=0X05; } void main(void) { unsigned char temp1,temp2; uchar x1=0; DDRB=0XFF; DDRA=0xff; DDRD&=0XF8; LCM_1602_Init(); temp1=0; temp2=0; LCM_Wr_CMD(0X80); while(LCM_Dis_String1[temp1]!='\0') { LCM_Wr_DAT(LCM_Dis_String1[temp1++]); delay_2(100); } LCM_Wr_CMD(0xc0); while(LCM_Dis_String2[temp2]!='\0') { LCM_Wr_DAT(LCM_Dis_String2[temp2++]); delay_2(100); } TCCR0=0X05; TCNT0=0X01; TCCR1B=0X04; TCNT1H=0XF0; TCNT1L=0XBE; TIMSK|=BIT(2); TIMSK|=BIT(0); SREG|=BIT(7); LCM_Wr_CMD(0XC0+0X0B); LCM_Wr_DAT('g'); LCM_Wr_DAT('/'); LCM_Wr_DAT('s'); while(1) /*读脉冲*/ { x1=PIND&0X01; if(x1=0) num++; } } 新手,所以上述这个程序花了两天多时间,还是不行,感觉一直在执行中断,不知道该怎么改,真心菜啊。求大神给支个招啊。
举报
zf_015820 发表于 2012-12-18 16:26 这个,用KEIL C51的断点,逐步调试,一下子就知道问题在那了呀;另外,你程序运行后,出现 了什么问题?现 ...
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
人才类勋章
时间类勋章
等级类勋章
发帖类勋章
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
