#include "libRain_M128.h" #include "MyLib.h"
#include "DriverUmIo.h" #include "ProtocolProtocol.h"
#include "TaskTask.h" #include "TaskImportKey.h" #include "TaskPWM_Wkv.h" #include "TriggleTriggle.h"
#include "TaskXPower.h" #include "TaskWaterLoop.h"
#include "WorkLedWorkLed.h"
//-------------------------------------------------------- //5ms中断回调函数 //-------------------------------------------------------- void CallBack_5msInterrupt( void ) { }
//-------------------------------------------------------- //20ms中断回调函数 //-------------------------------------------------------- void CallBack_20msInterrupt( void ) {
//-------------------------------------------------------- //析构 //-------------------------------------------------------- void Main_Destory( void ) { WatchDog_Destory();
//--------------------------user--------------------- Triggle_Destory(); PWM_Wkv_Destory(); ImportKey_Destory(); Task_Destory();
Protocol_Destory(); UmIo_Destory();
//--------------------------System--------------------- WorkLed_Destory();
Package_Destory();
VirtualUart80_Destory(); Uart80_Destory(); Uart81_Destory();
EDataBase_Destory(); CPU_Eeprom_Destory();
MyLib_Destory();
//-------------------------------------------------------- //初始化 //-------------------------------------------------------- void Main_Init( void ) { //--------------------------System--------------------- MyLib_Init();
CPU_Eeprom_Init(); EDataBase_Init( 4, 1, 500, CPU_Eeprom_Cmd );
Uart80_Setup( OSC_7p3728MHz_4800, (eUart80_NoneChk | eUart80_Stop1Bit), 250, 250 ); Uart81_Setup( OSC_7p3728MHz_4800, (eUart80_NoneChk | eUart80_Stop1Bit), 250, 250 ); VirtualUart80_Setup( 200, 200 ); //配置信息在VirtualUart80_IO.c中
Package_Init( 3 ); //三个协议转换任务
//--------------------------user--------------------- UmIo_Init(); Protocol_Init();
Task_Init(); ImportKey_Init(); PWM_Wkv_Init(); Triggle_Init();
XPower_Init(); WaterLoop_Init();
WorkLed_Init(); }
//-------------------------------------------------------- //主程序 //-------------------------------------------------------- int main( void ) { Main_Init();
Msg_RunInit(); //执行完全部初始化消息 WatchDog_Init(); //看门狗初始化 sei();
Package_Send( psUart_Import, eProto_RequAllState );
//开始主循环 while(1){ //--------------------------System--------------------- MyLib_MainLoop();
CPU_Eeprom_MainLoop(); EDataBase_MainLoop();
VirtualUart80_MainLoop(); Uart80_MainLoop(); Uart81_MainLoop();
Package_MainLoop();
//--------------------------user--------------------- UmIo_MainLoop(); Protocol_MainLoop();
PWM_Wkv_MainLoop(); Task_MainLoop(); ImportKey_MainLoop(); Triggle_MainLoop();
XPower_MainLoop(); WaterLoop_MainLoop();
WatchDog_MainLoop();
WorkLed_MainLoop(); } }
只要任意再添加一百个任务,即使TCP/IP也可以(当然要改造下),只要MCU能处理过来,同样也可以user下面任何一个任务去掉,而其它任务工作正常。这就是规则和约束的好处。
