Make: The target "E:\PIC_MCU\root_drv.o" is up to date.
Make: The target "E:\PIC_MCU\root_msg.o" is up to date.
Make: The target "E:\PIC_MCU\PIC_NEW_Proj.cof" is out of date.
Executing: "C:\mcc18\bin\mplink.exe" "app_init.o" "app_int.o" "app_sys.o" "app_timer.o" "CAN_driver.o" "can_msg.o" "config.o" "eeprom_op.o" "main.o" "mem_flash.o" "root_com.o" "root_drv.o" "root_msg.o" /o"PIC_NEW_Proj.cof" /M"PIC_NEW_Proj.map" /W
MPLINK 4.00, Linker
Copyright (c) 2005 Microchip Technology Inc.
Error - linker command file required.
Errors : 1
Link step failed.
Debug build of project `E:\PIC_MCU\PIC_NEW_Proj.mcp' failed.
Preprocessor symbol `__DEBUG' is defined.
Mon Feb 18 10:56:55 2013
BUILD FAILED
这个链接错误怎样去排查呢? |
