赛普拉斯 PSoC Creator 中文组件数据手册集锦
 楼主| Go_PSoC 发表于 2013-2-28 15:07 | 显示全部楼层 |阅读模式
计划把现有的应用笔记,芯片数据手册,用户模块数据手册,组件数据手册等集中起来,陆续在论坛里分享给大家,本帖为PSOC Creator组件数据手册部分。共78个
我会把列表列出来,大家可以告诉我哪些是你最需要的,我可以先上传这些
23/24/25/26/27/28/29/30楼有更新
 楼主| Go_PSoC 发表于 2013-2-28 15:09 | 显示全部楼层
External Memory Interface (EMIF)  1.30
http://china.cypress.com/?rID=56752
D Flip Flop 1.30
http://china.cypress.com/?rID=48911
Boost Converter (BoostConv) 4.0
http://china.cypress.com/?rID=46442
Inverting Programmable Gain  Amplifier (PGA_Inv) 2.0
http://china.cypress.com/?rID=48923
Power Monitor 1.30
http://china.cypress.com/?rID=63922
Precision Illumination Signal  Modulation (PrISM) 2.20
http://china.cypress.com/?rID=48890
Segment LCD (SegLCD) 3.30
http://china.cypress.com/?rID=48918
S/PDIF Transmitter (SPDIF_Tx) 1.20
http://china.cypress.com/?rID=56750
Serial Peripheral Interface (SPI)  Master 2.40
http://china.cypress.com/?rID=48906
PSoC® Creator™ System Reference  Guide (cy_boot Component) V3.30
http://china.cypress.com/?rID=51972
Analog Multiplexer (AMux) 1.70
http://china.cypress.com/?rID=46437
Analog Multiplexer Sequencer  (AMuxSeq) 1.70
http://china.cypress.com/?rID=46440
ADC Successive Approximation  Register (ADC_SAR) 2.0
http://china.cypress.com/?rID=46436
Digital Filter Block (DFB)  Assembler Component 1.20
http://china.cypress.com/?rID=60720
Filter 2.10
http://china.cypress.com/?rID=46458
Die Temperature (DieTemp) 2.0
http://china.cypress.com/?rID=46454
I2C Master/Multi-Master/Slave 3.30
http://china.cypress.com/?rID=51969
Inter-IC Sound Bus (I2S) 2.40
http://china.cypress.com/?rID=46464
Full Speed USB (USBFS) 2.50
http://china.cypress.com/?rID=48924
Pseudo Random Sequence (PRS) 2.20
http://china.cypress.com/?rID=46478
Pulse Width Modulator (PWM) 2.30
http://china.cypress.com/?rID=48869
Segment Display (Seg_Display) 1.20
http://china.cypress.com/?rID=56769
Comparator (Comp) 2.0
http://china.cypress.com/?rID=48915
Counter 2.30
http://china.cypress.com/?rID=48909
Cyclic Redundancy Check (CRC) 2.30
http://china.cypress.com/?rID=46448
Clock 2.0
http://china.cypress.com/?rID=46449
Direct Memory Access (DMA) 1.70
http://china.cypress.com/?rID=46450
Interrupt 1.70
http://china.cypress.com/?rID=46451
Pins 1.80
http://china.cypress.com/?rID=48513
Universal Asynchronous Receiver  Transmitter (UART) 2.30
http://china.cypress.com/?rID=48892
8-Bit Voltage Digital to Analog  Converter (VDAC8) 1.90
http://china.cypress.com/?rID=49054
Fan Controller 2.30
http://china.cypress.com/?rID=63918
LIN Slave 1.20
http://china.cypress.com/?rID=56718
Vector CAN 1.10
http://china.cypress.com/?rID=56768
Serial Peripheral Interface (SPI)  Slave 2.40
http://china.cypress.com/?rID=48908
Static Segment LCD (StaticSegLCD)  2.20
http://china.cypress.com/?rID=46487
Timer 2.40
http://china.cypress.com/?rID=48870
Mixer 2.0
http://china.cypress.com/?rID=48920
Sample/Track and Hold Component  (Sample_Hold) 1.40
http://china.cypress.com/?rID=56758
Operational Amplifier (Opamp) 1.90
http://china.cypress.com/?rID=48919
8-Bit Current Digital to Analog  Converter (IDAC8) 2.0
http://china.cypress.com/?rID=48914
Sleep Timer 3.20
http://china.cypress.com/?rID=48912
Real-Time Clock (RTC) 1.80
http://china.cypress.com/?rID=48907
Programmable Gain Amplifier (PGA)  2.0
http://china.cypress.com/?rID=48849
EEPROM 2.10
http://china.cypress.com/?rID=46455
File System Library (emFile) 1.20
http://china.cypress.com/?rID=58694
EZI2C Slave 1.80
http://china.cypress.com/?rID=48917
Status Register 1.80
http://china.cypress.com/?rID=46453
Capacitive Sensing (CapSense® CSD)  3.30
http://china.cypress.com/?rID=48884
Controller Area Network (CAN) 2.30
http://china.cypress.com/?rID=46443
Trans-Impedance Amplifier (TIA)  1.91
http://china.cypress.com/?rID=48921
Shift Register (ShiftReg) 2.10
http://china.cypress.com/?rID=48887
Resistive Touch (ResistiveTouch)  1.10
http://china.cypress.com/?rID=58690
Quadrature Decoder (QuadDec) 2.10
http://china.cypress.com/?rID=46480
Logic High/Logic Low
http://china.cypress.com/?rID=48514
Digital Logic Gates 1.0
http://china.cypress.com/?rID=48520
Digital Multiplexer and  De-Multiplexer 1.10
http://china.cypress.com/?rID=48518
Lookup Table (LUT) 1.50
http://china.cypress.com/?rID=46472
Graphic LCD Interface  (GraphicLCDIntf) 1.70
http://china.cypress.com/?rID=48854
Graphic LCD Controller  (GraphicLCDCtrl) 1.70
http://china.cypress.com/?rID=48850
Control Register 1.70
http://china.cypress.com/?rID=46452
Voltage Reference (Vref) 1.60
http://china.cypress.com/?rID=48512
Virtual Mux 1.0
http://china.cypress.com/?rID=48511
UDB Clock Enable v1.0
http://china.cypress.com/?rID=48865
Sync 1.0
http://china.cypress.com/?rID=48925
Stay Awake 1.50
http://china.cypress.com/?rID=51208
Character LCD 1.70
http://china.cypress.com/?rID=46445
Analog Net Constraint 1.50
http://china.cypress.com/?rID=69002
Delta Sigma Analog to Digital  Converter (ADC_DelSig) 2.30
http://china.cypress.com/?rID=48916
SEGGER emWin Graphic Library  (emWinGraphics) 1.0
http://china.cypress.com/?rID=58696
Annotation Library 1.0
http://china.cypress.com/?rID=56759
Analog Resource Constraint 1.50
http://china.cypress.com/?rID=56747
Analog Resource Reserve 1.50
http://china.cypress.com/?rID=56744
Terminal Reserve 1.50
http://china.cypress.com/?rID=56767
Net Join 1.50
http://china.cypress.com/?rID=56746
Analog Hardware Multiplexer  (AMuxHw) 1.50
http://china.cypress.com/?rID=46438
Analog No Connect 1.0
http://china.cypress.com/?rID=48913
Tri-State Buffer (Bufoe) 1.10
http://china.cypress.com/?rID=48510
 楼主| Go_PSoC 发表于 2013-2-28 15:22 | 显示全部楼层
8 位电流数模转换器 (IDAC8) 2.0
 楼主| Go_PSoC 发表于 2013-2-28 15:25 | 显示全部楼层
8 位电压数模转换器 (VDAC8) 1.90
 楼主| Go_PSoC 发表于 2013-3-1 14:48 | 显示全部楼层
Power Monitor 1.30
 楼主| Go_PSoC 发表于 2013-3-1 14:49 | 显示全部楼层
LCD行 (SegLCD) 3.30
 楼主| Go_PSoC 发表于 2013-3-1 14:55 | 显示全部楼层
串行外设接口 (SPI) 主 2.40
 楼主| Go_PSoC 发表于 2013-3-1 14:56 | 显示全部楼层
I2C 主/多-主/从 3.30
 楼主| Go_PSoC 发表于 2013-3-1 14:59 | 显示全部楼层
串行数字音频总线 (I2S)
 楼主| Go_PSoC 发表于 2013-3-1 15:02 | 显示全部楼层
全速 USB (USBFS)
 楼主| Go_PSoC 发表于 2013-3-1 15:03 | 显示全部楼层
ADC  逐次逼近寄存器 (ADC_SAR)
u880 发表于 2013-3-1 15:21 | 显示全部楼层
这次是组件集锦 好给力呀
huigoushang 发表于 2013-3-1 15:35 | 显示全部楼层
支持斑竹!辛苦了!
G21372 发表于 2013-3-1 15:59 | 显示全部楼层
强烈支持楼主,加油
yangguangaisha 发表于 2013-3-2 12:40 | 显示全部楼层
支持一下吧 呵呵
gexingyouxian 发表于 2013-3-2 14:06 | 显示全部楼层
楼主又有新动作啦
meishizhaoshi 发表于 2013-3-2 14:12 | 显示全部楼层
强烈支持,up!
wangjinlili 发表于 2013-3-2 20:06 | 显示全部楼层
还会有更新吗
teabottle 发表于 2013-3-2 20:10 | 显示全部楼层
好给力,顶你 楼主!
jinpaidianzi 发表于 2013-3-2 20:37 | 显示全部楼层
版主加油 支持你
个人签名:迷你,但包含一切——隆重推荐Cypress中文迷你网站:http://cypress.21ic.com/ 赛普拉斯官方微博开通啦!http://e.weibo.com/cypresschina
898
898
