RT0802B-1液晶显示
 楼主| wanxindong 发表于 2009-3-26 21:43 | 显示全部楼层 |阅读模式
高手们,谁有RT0802B-1的驱动程序啊?只要能点亮其中一个数字就好的
刚写了一个,可怎么也调不通.请高手指教
;RT0802B-1      显示测试部分程序
CS      bit     p2.0        ;片选信号  下降沿       enable  signel
RW      bit     p2.1        ;读写信号  H 读  L 写
RS      bit     p2.2        ;register  selcet input
; DB0 - DB7  select P10 - P17
                     org   0000h
                     ljmp  main
                     org   0003h
main:
        call   delay_400ms
        mov    p2,    #0f0h
        mov    r0,    #03h
wait:
        clr    rs
        clr    rw
        mov    p1,    #30h
        setb   cs
        clr    cs
        call   delay_400ms
        djnz   r0,  wait
        call   delay_400ms
        mov    a,  #38h       ;DL=1  8 bit data    N=0  1 行 ; F=0  5* 7 dot字形    function set
        call   LCD_sendcmd
        mov    a,  #01h       ;clear  display
        call   LCD_sendcmd
        mov    a,   #07h   ; AC IN
        call   LCD_sendcmd
        mov    a,   #10h   ; display on     D=1
        call   LCD_sendcmd
        mov    a,   #0ch   ; display on     D=1
        call   LCD_sendcmd
        ;mov    a,   #80h   ;ddram  address
        ;call   LCD_sendcmd
        call   delay_400ms
        mov    r2,  #50h
disp_loop:
        mov    a,   #0feh
        call   LCD_senddat
        djnz   r2,  disp_loop
        mov    a,    #02h    ; display  return
        call   LCD_sendcmd
        call   delay_400ms
        mov    r2,   #50h
disp_loop1:
        mov    a,   #0FEH
        call   LCD_senddat
        djnz   r2,   disp_loop1
        mov    a,    #02h
        call   LCD_sendcmd
        call   delay_400ms
        mov    r2,   #50h
disp_loop2:
        mov    a,   #0FEH
        call   LCD_senddat
        djnz   r2,   disp_loop2
        mov    a,    #02h
        call   LCD_sendcmd
        call   delay_400ms
        mov    r2,    #50h
        mov    a,     #20h
disp_loop3:
        inc    a
        call   LCD_senddat
        djnz   r2,    disp_loop3
        mov    a,    #02h
        call   LCD_sendcmd
        call   delay_400ms
        ljmp   main
LCD_senddat:
        setb   RS
        setb   RS
        clr    RW
        clr    RW
        setb   CS
        setb   CS
        mov    p1, a
        mov    p1, a
        clr    CS
        clr    CS
        mov    r1,  #0ffh
        djnz   r1,  $
        ret
LCD_sendcmd:
        clr    RW     ;write
        clr    RW
        clr    RS     ;指令寄存器
        clr    RS
        setb   CS     ;片选信号 clear
        setb   CS
        mov    p1, A ; 指令
        mov    p1, A
        clr    CS     ; 片选信号选通
        clr    CS
        mov    r0,  #02h
delay_loop:
        mov    r1,  #0ffh
        djnz   r1,  $
        djnz   r0,  delay_loop
        ret
delay_400ms:
      call   delay_130ms
      call   delay_130ms
      call   delay_130ms
      ret
delay_130ms:
        mov    r0,   #0ffh
delay_130ms_loop:
        mov    r1,   #0ffh
        djnz   r1,   $
        djnz   r0,   delay_130ms_loop
        ret
        end
 楼主| wanxindong 发表于 2009-3-27 10:43 | 显示全部楼层
RT0802B-1液晶显示
高手们,回个话呀.
