john_light请看,我在.M51里复制过来的 方法1、如下定义这两个全局变量:(运行结果不正确的) ulong xdata compare_value[2]; uint xdata ct_once; 编译后结果: Program Size: data=16.7 xdata=436 code=31331 creating hex file from "panel_disp"... "panel_disp" - 0 Error(s), 0 Warning(s).
.M51结果: X:0136H PUBLIC compare_value X:013EH PUBLIC ct_once 方法2、如下定义这两个全局变量:(运行结果正确的) ulong data compare_value[2]; uint xdata ct_once; 编译后结果: Program Size: data=24.7 xdata=428 code=31053 creating hex file from "panel_disp"... "panel_disp" - 0 Error(s), 0 Warning(s). .M51结果: D:0008H PUBLIC compare_value X:0136H PUBLIC ct_once
请john_light帮我看看方法1为什么ct_once会变
