在做完原理图以后生成PCB的时候提示节点找不到,可那些节点我都没用到,这是怎么回事啊?<br /> 具体错误见下:<br />ERRORS: 6 macros can not be executed:<br />-------------------------------------------------------------------------<br />Macro 1: New Node<br />Add node D1-1 to net AREFN<br />Error: Node not found<br /><br />Macro 2: New Node<br />Add node D2-2 to net AREFN<br />Error: Node not found<br /><br />Macro 3: New Node<br />Add node -A to net NetR18_1<br />Error: Node not found<br /><br />Macro 4: New Node<br />Add node D1-2 to net VSS<br />Error: Node not found<br /><br />Macro 5: New Node<br />Add node D2-1 to net VSS<br />Error: Node not found<br /><br />Macro 6: New Node<br />Add node -K to net VSS<br />Error: Node not found |
