PCB加工工艺的一些参数 zz
 楼主| limee 发表于 2007-2-24 15:34 | 显示全部楼层 |阅读模式
层数(Layers&nbsp;counts)&nbsp;2-16层(Layers)&nbsp;<br />板厚(Board&nbsp;thickness)&nbsp;0.6MM---6MM&nbsp;<br />材料(Material)&nbsp;FR4&nbsp;/&nbsp;CEM-3&nbsp;/&nbsp;高Tg&nbsp;/&nbsp;Teflon&nbsp;/&nbsp;Rogers.....&nbsp;<br />表面处理(Surface&nbsp;finishes)&nbsp;热风整平、无铅喷锡、化学沉镍金、<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;金手指、全板镀金、OSP&nbsp;<br />最小线宽&nbsp;/&nbsp;线距(Min.line&nbsp;width/spacing)&nbsp;4/4MIL&nbsp;<br />最小孔(Min.hole&nbsp;size)&nbsp;0.25MM&nbsp;<br />最大板厚孔径比(Max.Aspect&nbsp;Ratio)&nbsp;8:1&nbsp;<br />最大板面尺寸(Max.pannel&nbsp;size)&nbsp;20*20&nbsp;<br />最小阻焊桥(Max.solder&nbsp;mask&nbsp;gap&nbsp;between&nbsp;dam)&nbsp;4MIL&nbsp;<br />最大铜厚(Max.copper&nbsp;thickness)&nbsp;外层7OZ、内层5OZ&nbsp;<br />
