加了一个c文件后编译总会报错
 楼主| heweibig 发表于 2013-5-14 18:53 | 显示全部楼层 |阅读模式
之前是ti的一个诊断工程,我加了一个c文件后编译总会报错
wuhany 发表于 2013-5-14 18:53 | 显示全部楼层
不懂,帮顶
jiajs 发表于 2013-5-14 18:55 | 显示全部楼层
你说的太简单了
 楼主| heweibig 发表于 2013-5-14 18:55 | 显示全部楼层
[Linking...] "D:\Program Files\Texas Instruments\TMS470 Code Generation Tools 4.6.6\bin\cl470" [email=-@]-@"Debug.lkf[/email]"
<Linking>
"C:\\DOCUME~1\\ADMINI~1\\LOCALS~1\\Temp\\045963", line 19: error: cannot find
    file
    "E:\\PrivateTI_IPNC_DM36x\\Utils\\diagnostic_ipnc_dm36x_1.0.0\\DM36x_IPCAM\\
    Build\\Debug\\ApproCalFunc.obj"
undefined         first referenced
   symbol               in file
_Appro3Afunction  E:\\PrivateTI_IPNC_DM36x\\Utils\\diagnostic_ipnc_dm36x_1.0.0\\DM36x_IPCAM\\Build\\Debug\\main.obj
_ApproWBSetPrm    E:\\PrivateTI_IPNC_DM36x\\Utils\\diagnostic_ipnc_dm36x_1.0.0\\DM36x_IPCAM\\Build\\Debug\\main.obj
_EVMDM365_init    E:\\PrivateTI_IPNC_DM36x\\Utils\\diagnostic_ipnc_dm36x_1.0.0\\DM36x_IPCAM\\Build\\Debug\\test.obj
_Resize_ping_pong E:\\PrivateTI_IPNC_DM36x\\Utils\\diagnostic_ipnc_dm36x_1.0.0\\DM36x_IPCAM\\Build\\Debug\\main.obj
_VD_Send_Appro3A  E:\\PrivateTI_IPNC_DM36x\\Utils\\diagnostic_ipnc_dm36x_1.0.0\\DM36x_IPCAM\\Build\\Debug\\main.obj
_pause_aweb       E:\\PrivateTI_IPNC_DM36x\\Utils\\diagnostic_ipnc_dm36x_1.0.0\\DM36x_IPCAM\\Build\\Debug\\main.obj
_y_mean           E:\\PrivateTI_IPNC_DM36x\\Utils\\diagnostic_ipnc_dm36x_1.0.0\\DM36x_IPCAM\\Build\\Debug\\main.obj
error: unresolved symbols remain
error: errors encountered during linking; "./Output/DM368_DEB.out" not built
>> Compilation failure
Build Complete,
   2 Errors, 2 Warnings, 0 Remarks.
Recursive Build Complete,
   Total Count: 2 Errors, 2 Warnings, 0 Remarks.
zhaoxqi 发表于 2013-5-14 18:57 | 显示全部楼层
没有文件啊
 楼主| heweibig 发表于 2013-5-14 18:57 | 显示全部楼层
算了,结贴了
chenci2013 发表于 2013-5-14 23:21 | 显示全部楼层
你是不是又两个main?
一个test 一个在mail里面?
jlass 发表于 2013-5-15 16:06 | 显示全部楼层
好像以前也遇到过,提示在Temp下缺文件,应该是C文件的问题,没什么印象了
huangfeng33 发表于 2013-5-15 20:42 | 显示全部楼层
经常会遇到的问题,楼主结贴了,解决了吗?分享一下啊
