TMS320C6713DSP上电自启动问题
 楼主| nobodyshow2716 发表于 2013-6-12 23:18 | 显示全部楼层 |阅读模式
我是一个新手,最近在学习TMS320C6713DSP上电自启动问题,我用的是TI公司的DSK开发板,上边有例程,例程中的boot.asm文件是bootload文件,我有一个问题,下面这个程序中是不是没办法运行到“zero  a1”到“[ a1]  add   4,a5,a3”这几条语句?这个程序是不是没办法实现程序的搬移?程序代码如下。盼望各位前辈可以不吝赐教!
.title  "Flash bootup utility for 6713 dsk"
            .option D,T
            .length 102
            .width  140
COPY_TABLE    .equ    0x90000400
            .sect ".boot_load"
            .global _boot
_boot:
;* Copy code sections
        mvkl  COPY_TABLE, a3   ; load table pointer
        mvkh  COPY_TABLE, a3
        ldw   *a3++, b1        ; Load entry point
copy_section_top:
        ldw   *a3++, b0        ; byte count
        ldw   *a3++, a4        ; ram start address
        nop   3
[!b0]  b copy_done            ; have we copied all sections?
        nop   5
copy_loop:
        ldb   *a3++,b5
        sub   b0,1,b0          ; decrement counter
[ b0]  b     copy_loop        ; setup branch if not done
[!b0]  b     copy_section_top
        zero  a1
[!b0]  and   3,a3,a1
        stb   b5,*a4++
[!b0]  and   -4,a3,a5         ; round address up to next multiple of 4
[ a1]  add   4,a5,a3          ; round address up to next multiple of 4
;* Jump to entry point
copy_done:
        b    .S2 b1
        nop   5
