We can provide DC-100MHz wideband isolation amplifier module. The specifications are shown below: Bandwidth: DC-100MHz Maximum Working Insulation Voltage: 1414Vpeak Input-Output Momentary-Withstand Voltage (t=1min): 5000Vrms Highest Allowable Overvoltage (Transient Overvoltage, t = 10 sec): 8000Vpeak Input-Output Resistance: >2 G ohm Gain: Can be set from x1 to x10 Gain Nonlinearity: <1% Maximum output voltage: ±1.5V Output Noise: <2mVrms Power Supply: ±5V x2 Operating Temperature: -10°C to+70°C Dimensions: 90mmx53mmx10mm http://www.cheele.cn/data/skins/chinese024/eng_01.htm |
