- #include "lwip/tcp.h"
- #include "lwip/err.h"
- #include "stm32f10x.h"
- #include <string.h>
- #include <stdio.h>
- extern struct netif *enc28j60;
- enum tcp_client_state{
- CLIENT_CONNECTED = 0x00U,
- CLIENT_WAITING_FOR_CMD,
- CLIENT_BUSY,
- CLIENT_SENT,
- CLIENT_ERROR,
- CLIENT_CLOSE,
- CLIENT_WAITING_FOR_CONNECTION
- struct tcp_client_app_arg{
- uint8_t app_state;
- uint8_t textlen;
- uint8_t* dataptr;
- static struct ip_addr destip;
- void tcp_client_errf(void *arg, err_t err)
- struct tcp_client_app_arg* pro_arg = (struct tcp_client_app_arg*)arg;
- printf("tcp client err\n");
- pro_arg->app_state = CLIENT_ERROR;
- switch(err){
- case ERR_MEM: printf("Out of memory error\n"); break;
- case ERR_BUF: printf("Buffer error\n"); break;
- case ERR_TIMEOUT: printf("Timeout\n"); break;
- case ERR_RTE: printf("Routing problem\n"); break;
- case ERR_ABRT: printf("Connection aborted\n"); break;
- case ERR_RST: printf("Connection reset\n"); break;
- case ERR_CLSD: printf("Connection closed\n"); break;
- case ERR_CONN: printf("Not connected\n"); break;
- case ERR_VAL: printf("Illegal value\n"); break;
- case ERR_ARG: printf("Illegal argument\n"); break;
- case ERR_USE: printf("Address in use\n"); break;
- case ERR_IF: printf("Low-level netif error\n"); break;
- case ERR_ISCONN: printf("Already connected\n"); break;
- case ERR_INPROGRESS: printf("Operation in progress\n"); break;
- default: printf("Unknown error\n");
- err_t tcp_client_recv(void *arg, struct tcp_pcb *pcb, struct pbuf *p, err_t err)
- struct pbuf *q;
- struct tcp_client_app_arg *appcmd = (struct tcp_client_app_arg *)arg;
- uint16_t i = 0;
- uint8_t ip[4];
- uint8_t* str;
- const char* cmd1 = "hello";
- const char* cmd2 = "LEDON";
- const char* cmd3 = "LEDOFF";
- const char* cmd4 = "echo IP";
- const char* cmd5 = "bye";
- printf("tcp client recieve\n");
- /* We perform here any necessary processing on the pbuf */
- if (p != NULL)
- /* We call this function to tell the LwIp that we have processed the data */
- /* This lets the stack advertise a larger window, so more data can be received*/
- tcp_recved(pcb, p->tot_len);
- /* Check the name if NULL, no data passed, return withh illegal argument error */
- if(appcmd == NULL)
- pbuf_free(p);
- return ERR_ARG;
- appcmd->dataptr = (uint8_t*)mem_calloc(sizeof(uint8_t), p->tot_len);
- if(appcmd->dataptr == NULL){
- printf("Memory error\n");
- return ERR_MEM;
- appcmd->textlen = p->tot_len;
- for(q=p; q!=NULL; q=q->next){
- memcpy((uint8_t*)&appcmd->dataptr[i], q->payload, q->len); //同一个数据包会存在一个pbuf链表中
- i = i + q->len;
- //应用层代码
- switch(appcmd->app_state){
- case CLIENT_CONNECTED:
- case CLIENT_WAITING_FOR_CMD: {
- if(memcmp(appcmd->dataptr, cmd1, strlen(cmd1)) == 0)
- str = "hello\n";
- // tcp_write(pcb, (uint8_t*)str, strlen(str), 1);
- else if(memcmp(appcmd->dataptr, cmd2, strlen(cmd2)) == 0)
- GPIO_ResetBits(GPIOF,GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9);
- str="LEDON\n";
- //还可以加上这样
- /*if(GPIO_ReadInputDataBit(GPIOF,GPIO_Pin_6) == RESET)str="LEDON\n";*/
- else if(memcmp(appcmd->dataptr, cmd3, strlen(cmd3)) == 0)
- GPIO_SetBits(GPIOF,GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9);
- str="LEDOFF\n";
- else if(memcmp(appcmd->dataptr, cmd4, strlen(cmd4)) == 0)
- ip[0] = 192;
- ip[1] = 168;
- ip[2] = 0;
- ip[3] = 16;
- // ip[0] = enc28j60->ip_addr.addr>>24; //打出来有点不对
- // ip[1] = enc28j60->ip_addr.addr>>16;
- // ip[2] = enc28j60->ip_addr.addr>>8;
- // ip[3] = enc28j60->ip_addr.addr;
- // ip[0] = pcb->remote_ip.addr>>24;
- // ip[1] = pcb->remote_ip.addr>>16;
- // ip[2] = pcb->remote_ip.addr>>8;
- // ip[3] = pcb->remote_ip.addr;
- str = mem_calloc(sizeof(uint8_t), 30);
- sprintf((char*)str, "ipaddr:%d,%d,%d,%d\n", ip[3], ip[2], ip[1], ip[0]);
- tcp_write(pcb, (const char *)str, strlen(str), 1);
- mem_free(str);
- break;
- else if(memcmp(appcmd->dataptr, cmd5, strlen(cmd5)) == 0)
- appcmd->app_state = CLIENT_CLOSE;
- break;
- else
- str = "unknown cmd\n";
- break;
- default:
- str = "lwip down\n";
- break;
- mem_free(appcmd->dataptr);
- //取得应用层数据后,先释放pbuf队列相应数据链,再对数据进行解析与执行操作
- /* End of processing, we free the pbuf */
- pbuf_free(p);
- else if (err == ERR_OK)
- /* When the pbuf is NULL and the err is ERR_OK, the remote end
- is closing the connection. */
- /* We free the allocated memory and we close the connection */
- mem_free(appcmd);
- return tcp_close(pcb);
- return ERR_OK;
- err_t tcp_client_sent(void *arg, struct tcp_pcb *pcb, u16_t len)
- printf("tcp client sent\n");
- switch(pro_arg->app_state){
- case CLIENT_WAITING_FOR_CMD:{
- printf("acked!\n");
- break;
- case CLIENT_CLOSE:{
- mem_free(pro_arg);
- default:{}
- return ERR_OK;
- err_t tcp_client_poll(void *arg, struct tcp_pcb *pcb)
- const char* str = "The data come from the stm32 client\n";
- printf("tcp client poll\n");
- tcp_write(pcb, (const char*)str, strlen(str), 1);
- return ERR_OK;
- err_t tcp_client_connected(void *arg, struct tcp_pcb *pcb, err_t err)
- struct tcp_client_app_arg* app_arg = (struct tcp_client_app_arg*)arg;
- uint8_t* str = "Welcome to the client\n";
- printf("tcp client connected\n");
- tcp_err(pcb, tcp_client_errf); //指定出错时的回调函数
- tcp_recv(pcb, tcp_client_recv); //指定接收到新数据时的回调函数
- tcp_sent(pcb, tcp_client_sent); //指定远程主机成功接收到数据的回调函数
- tcp_poll(pcb, tcp_client_poll, 4); //指定轮询的时间间隔和回调函数(*250ms)
- app_arg->app_state = CLIENT_WAITING_FOR_CMD;
- return ERR_OK;
- void tcp_client_init(void)
- struct tcp_pcb* client_pcb;
- struct tcp_client_app_arg* app_arg;
- printf("tcp client inti\n");
- destip.addr = (uint32_t)192+(168<<8)+(0<<16)+(105<<24);
- client_pcb = tcp_new();
- if(client_pcb != NULL)
- // tcp_bind(client_pcb,IP_ADDR_ANY,2200);
- tcp_arg(client_pcb, mem_calloc(sizeof(struct tcp_client_app_arg), 1));
- app_arg = client_pcb->callback_arg;
- app_arg->app_state = CLIENT_WAITING_FOR_CONNECTION;
- tcp_connect(client_pcb, &destip, 2200, tcp_client_connected); //按需求连接,加上条件
- else
- printf("tcp alloc failed\n");
