[AVR单片机] 初学AVR mega16问题忘各位大神指点
1543|1
 楼主| agz1989 发表于 2013-10-22 21:57 | 显示全部楼层 |阅读模式
外部中断按下按钮之后没中断
以下是硬件电路
#include "mega16.h"
#define uchar unsigned char
#define button1 PIND.2
#define button2 PIND.3
#define sounder PORTD.0
int a;
flash uchar tab[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f,
                         0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe,
                         0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
flash uchar tab2[]={0xf0,0x0f,0xf0,0x0f,0xf0,0x0f};
void delay (int k)
int i,j;
for(i=0;i<k;i++)
    for(j=0;j<1140;j++);
interrupt[EXT_INT0]void int0()
int i;
for(i=0;i<500;i++)
    sounder=1;
    delay(2);
    sounder=1;
    delay(2);
interrupt[EXT_INT1]void int1()
int i,j;
a++;
#asm("sei")
if(a%2==0)
    for(i=0;i<6;i++)
        tab2[i];
        delay(5);
else
     for(j=0;j<24;j++)
        tab[j];
        delay(5);
void main()
DDRC=0xff;
PORTC=0xff;
DDRD=0xf3;
PORTD=0xff;
MCUCR=0x0a;
GICR=0xc0;
#asm("sei")
while(1)
  PORTC=0xff;
  delay(500);
  PORTC=0x00;
  delay(500);
qin552011373 发表于 2013-10-24 13:30 | 显示全部楼层
开发环境都没写,还有你是怎么调试的,问问题的方法也不对
