使用STM32的SPI2链接NRF2L01,使用单步调试,NRF24LO1可以正常的设置,状态REG的值也正确,
而直接运行后,NRF24L01的状态REG的值就不对了。哪位大侠帮我看下啊,,,,,
已经两个星期了,搞不定啊。。。。。。
void nrf_spi2_init(void)
SPI_InitTypeDef SPI_InitStructure;
/* SPI1 Init, before continuing, start the spio clock */
RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOE, ENABLE );
RCC_APB2PeriphClockCmd( RCC_APB2Periph_AFIO, ENABLE);
RCC_APB1PeriphClockCmd( RCC_APB1Periph_SPI2, ENABLE);
/* initialize GPIO A5.A6.A7 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO B5 --- CSN(SPI NSS chip select)
GPIO B6 --- CE (chip mode set)
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_5;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
idle
NRF_HIGH(NRFB_CSE_PORT, NRFB_CSE_PIN);
NRF_LOW(NRFB_CE_PORT, NRFB_CE_PIN);
GPIO B1 for nRF2401 IRQ
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
SPI_Cmd(SPI2, DISABLE);
/* configure spi1 */
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_Low;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_256;
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_InitStructure.SPI_CRCPolynomial = 7;
SPI_Init(SPI2, &SPI_InitStructure);
/* enable spi */
SPI_Cmd(SPI2, ENABLE);
void nrf_spi_rxmode(SPI_TypeDef* SPIx, unsigned char *dest_addr, int len, unsigned char channel)
NRF_CE_LOW(SPIx); // 拉底CE不是CS
if(SPI1 == SPIx)
NRF_LOW(NRFA_CE_PORT, NRFA_CE_PIN);
else
nrf_spi_writereg(SPIx, OPT_FLUSH_RX, 0xff); // RESET Receive FIFO
nrf_spi_writebuf(SPIx, OPT_W_REGISTER + RA_RX_ADDR_P0, dest_addr, len); // 指定接收地址,只接受目的地址是指定地址的数据
nrf_spi_writereg(SPIx, OPT_W_REGISTER + RA_EN_AA, 0x01); // 使能通道0自动应答
nrf_spi_writereg(SPIx, OPT_W_REGISTER + RA_EN_RXADDR, 0x01); // 使能接收通道0
nrf_spi_writereg(SPIx, OPT_W_REGISTER + RA_RF_CH, channel); // 选择射频频段
nrf_spi_writereg(SPIx, OPT_W_REGISTER + RA_RX_PW_P0, NRF_FRAM_LEN); // 设置接收数据长度
nrf_spi_writereg(SPIx, OPT_W_REGISTER + RA_RF_SETUP, 0x07); // 数据传输率1Mbps,发射功率0dBm,低噪声放大器增益
nrf_spi_writereg(SPIx, OPT_W_REGISTER + RA_CONFIG, 0x03); // CRC使能,16位CRC校验,上电,接收模式
NRF_CE_HIGH(SPIx); // 拉高CE
delay_ms(100);
void nrf_spi_txmode(SPI_TypeDef* SPIx, unsigned char *dest_addr, int dest_len, unsigned char channel)
nrf_spi_writereg(SPIx, OPT_FLUSH_TX, 0xff); // RESET send FIFO
nrf_spi_writebuf(SPIx, OPT_W_REGISTER + RA_TX_ADDR,dest_addr, dest_len); //写TX节点地址
nrf_spi_writebuf(SPIx, OPT_W_REGISTER + RA_RX_ADDR_P0, dest_addr, dest_len); //设置TX节点地址,主要为了使能ACK
// nrf_spi_writebuf(SPIx, OPT_W_TX_PAYLOAD, buf, buflen); // 装载数据
nrf_spi_writereg(SPIx, OPT_W_REGISTER + RA_EN_AA, 0x01); // 频道0自动 ACK应答允许
nrf_spi_writereg(SPIx, OPT_W_REGISTER + RA_EN_RXADDR, 0x01); // 允许接收地址只有频道0,如果需要多频道可以参考Page21
nrf_spi_writereg(SPIx, OPT_W_REGISTER + RA_SETUP_RETR, 0x1a); // 设置自动重发时间和次数:500us + 86us, 10 retrans...
nrf_spi_writereg(SPIx, OPT_W_REGISTER + RA_RF_CH, channel); // 设置信道工作为2.4GHZ,收发必须一致
// nrf_spi_writereg(SPIx, OPT_W_REGISTER + RA_RX_PW_P0, NRF_FRAM_LEN); //NRF_FRAM_LEN //设置接收数据长度,本次设置为32字节
nrf_spi_writereg(SPIx, OPT_W_REGISTER + RA_RF_SETUP, 0x07); //设置发射速率为1MHZ,发射功率为最大值0dB
nrf_spi_writereg(SPIx, OPT_W_REGISTER + RA_CONFIG, 0x02);//0x0E);
// delay_ms(100); // CE 拉高要持续一段时间
void main(void *p_arg)
unsigned char channel = 128;
unsigned char spi1_addr[5] = {0x5,0x4,0x3,0x2,0x1};
unsigned char spi2_addr[5] = {0x5,0x4,0x3,0x2,0x2};
unsigned char senddata[32] = {0x6,0x6,0x6,0x6,0x6,0x6,0x6,0x6,0x6,0x6,
0x6,0x6};
int err = 0;
unsigned char status = 0;
nrf_spi1_init();
nrf_spi2_init();
// mySPI_Init();
// nrf_spi_irqconfig(); // 配置中断等
// sp1 进入接收模式
nrf_spi_rxmode(SPI1, spi2_addr, 5, channel);
// sp2 发送模式,并发送数据
nrf_spi_txmode(SPI2, spi2_addr, 5, channel);
// sp2 发送数据
nrf_spi_sendframe(SPI2, spi2_addr, 5, senddata, 32);
while(1)
status = nrf_spi_readreg(SPI1, RA_STATUS); // 读取状态寄存其来判断中断原因
status = nrf_spi_readreg(SPI2, RA_STATUS); // 读取状态寄存其来判断中断原因
if(status == 0)
err++;
