STM32 USB键盘按shift&ctrl等键一直在发数据,why?谢谢。
 楼主| lhchen922 发表于 2013-10-30 14:49 | 显示全部楼层 |阅读模式
用STM32做键盘,鼠标,触摸屏,功能均实现,但当按住键盘的CTRL,SHIFT键时,用BUS HOUND监测到USB在一直发这些键值到PC,且有按住CTRL,SHIFT的功能。。
Bus Hound 6.01 capture on Windows Vista (x86). Complements of www.perisoft.net
  Device - Device ID (followed by the endpoint for USB devices)
            (23) USB Composite Device
            (24) USB Input Device
            (25) USB Input Device
            (26) USB Input Device
            (27) HID-compliant mouse
            (28) HID Keyboard Device
            (29) HID-compliant mouse
  Phase  - Phase Type
            IN    Data in transfer
  Data   - Hex dump of the data transferred
  Descr  - Description of the phase
  Cmd... - Position in the captured data
Device  Phase  Data                      Description       Cmd.Phase.Ofs(rep)
  25.2  IN     01 01 00 00  00 00 00 00  ........                 1.1.0
  28    IN     10 00 1d 00  00 00 00 00  ........                 2.1.0
  25.2  IN     00 00 00 00  00 00 00 00  ........                 3.1.0
  25.2  IN     01 01 00 00  00 00 00 00  ........                 4.1.0
  25.2  IN     00 00 00 00  00 00 00 00  ........                 5.1.0
  28    IN     10 00 1d 00  00 00 00 00  ........                 6.1.0(6982) //发送次数。
如果我有在回调函数里面发送一包0,那么就不能连续按按键(比如按住backspace,一直退格),
求指教,谢谢。。
香水城主 发表于 2013-10-30 16:10 | 显示全部楼层
什么键盘?
 楼主| lhchen922 发表于 2013-10-30 17:58 | 显示全部楼层
背景:我的设备如图,STM32-2端可以接USB,PS2键盘,鼠标,然后通过RS485发给STM32-1,我把STM32-1枚举成鼠标,键盘,
现在的基本功能已经实现,
不知道城主是指哪方面? DELL USB键盘啊。。
刚才发现,如果STM32-2端不接PS2键盘,只单独接USB键盘,按住键盘的CTRL,SHIFT键,没问题,但是如果同时接PS2和USB键盘,就出现上面的现象,
调试发现,STM32-2端同时接PS2和USB键盘,和STM32-2端只接USB键盘,在STM32-2端发送的数据都是一样的,且STM32-1端接收的数据也是一样.
而PC端用BUS HOUND监测到这两种状态的数据却不同,求解,,谢谢。。。BUS HOUND数据如下:
1.STM32-2端只接USB键盘的:
            (26) HID-compliant mouse
            (27) HID Keyboard Device
            (30) USB Input Device
            (31) HID-compliant mouse
            (32) Unknown Device
  Phase  - Phase Type
            IN    Data in transfer
  27    IN     01 00 1d 00  00 00 00 00  ........                 2.1.0
  25.2  IN     01 00 00 00  00 00 00 00  ........                 3.1.0
  27    IN     01 00 1d 00  01 00 00 00  ........                 4.1.0
  25.2  IN     01 00 00 00  00 00 00 00  ........                 5.1.0
  25.2  IN     00 00 00 00  00 00 00 00  ........                 6.1.0
  25.2  IN     01 00 00 00  1e 00 00 00  ........                 7.1.0
  27    IN     01 00 02 00  00 00 00 00  ........                 8.1.0
  25.2  IN     00 00 00 00  00 00 00 00  ........                 9.1.0
  25.2  IN     01 00 00 00  00 00 00 00  ........                10.1.0
  27    IN     01 00 02 00  01 00 00 00  ........                11.1.0
2.STM32-2端同时接USB键盘和PS2键盘的
D
            (32) Unknown Device
  Phase  - Phase Type
            IN    Data in transfer
  25.2  IN     01 01 00 00  00 00 00 00  ........                 1.1.0(2)
  27    IN     01 00 1d 00  00 00 00 00  ........                 2.1.0(2)
  25.2  IN     01 00 00 00  00 00 00 00  ........                 3.1.0(2)
  27    IN     01 00 1d 00  01 00 00 00  ........                 4.1.0(2)
 楼主| lhchen922 发表于 2013-10-30 19:13 | 显示全部楼层
续上,搞不清楚NG的时候为什么连续发了两次.......
 楼主| lhchen922 发表于 2013-10-31 09:08 | 显示全部楼层
求指教。。
huaziforever 发表于 2013-10-31 11:12 | 显示全部楼层
发送了按下的数据后当然要发送弹起的数据啊,你可以连接一个usb键盘看看数据;
 楼主| lhchen922 发表于 2013-10-31 12:41 | 显示全部楼层
每次有发弹起的数据,现在的问题是同时接上PS2键盘后,把USB的数据好像打乱了,,再找找。
谢谢楼上。
 楼主| lhchen922 发表于 2013-10-31 15:36 | 显示全部楼层
搞定了。。。呵呵。
 楼主| lhchen922 发表于 2013-10-31 15:37 | 显示全部楼层
我怎么老是没分。。。。
jiutianlanyue3 发表于 2018-8-28 18:10 来自手机 | 显示全部楼层
请问楼主是怎么解决的,我现在的问题是按下一次按键后就一直不停的发送这个键的键值,松开后还不停的发
jiutianlanyue3 发表于 2018-8-28 18:11 来自手机 | 显示全部楼层
弹起的数据是啥啊
个人签名:<a href="=http://ip.WoTuLa.com" target="_blank"><img src="http://id.WoTuLa.com/1/?name=心有所向&style=2&font=6" /></a>
18
