Building configuration: ADC - Debug_RAM
Updating build tree...
lpc23xx_cstartup.s79
Error[40]: Bad instruction C:\Documents and Settings\Administrator\桌面\新建文件夹\LPC23XX_IAR_Demo\code.lpc23xx.peripherals.iar\Common\src\lpc23xx_cstartup.s79 52
Error[40]: Bad instruction C:\Documents and Settings\Administrator\桌面\新建文件夹\LPC23XX_IAR_Demo\code.lpc23xx.peripherals.iar\Common\src\lpc23xx_cstartup.s79 57
Error[40]: Bad instruction C:\Documents and Settings\Administrator\桌面\新建文件夹\LPC23XX_IAR_Demo\code.lpc23xx.peripherals.iar\Common\src\lpc23xx_cstartup.s79 62
Error[40]: Bad instruction C:\Documents and Settings\Administrator\桌面\新建文件夹\LPC23XX_IAR_Demo\code.lpc23xx.peripherals.iar\Common\src\lpc23xx_cstartup.s79 64
Error[40]: Bad instruction C:\Documents and Settings\Administrator\桌面\新建文件夹\LPC23XX_IAR_Demo\code.lpc23xx.peripherals.iar\Common\src\lpc23xx_cstartup.s79 66
Error[40]: Bad instruction C:\Documents and Settings\Administrator\桌面\新建文件夹\LPC23XX_IAR_Demo\code.lpc23xx.peripherals.iar\Common\src\lpc23xx_cstartup.s79 68
Error[40]: Bad instruction C:\Documents and Settings\Administrator\桌面\新建文件夹\LPC23XX_IAR_Demo\code.lpc23xx.peripherals.iar\Common\src\lpc23xx_cstartup.s79 71
Error[40]: Bad instruction C:\Documents and Settings\Administrator\桌面\新建文件夹\LPC23XX_IAR_Demo\code.lpc23xx.peripherals.iar\Common\src\lpc23xx_cstartup.s79 73
Error[40]: Bad instruction C:\Documents and Settings\Administrator\桌面\新建文件夹\LPC23XX_IAR_Demo\code.lpc23xx.peripherals.iar\Common\src\lpc23xx_cstartup.s79 79
Error[40]: Bad instruction C:\Documents and Settings\Administrator\桌面\新建文件夹\LPC23XX_IAR_Demo\code.lpc23xx.peripherals.iar\Common\src\lpc23xx_cstartup.s79 81
Error[40]: Bad instruction C:\Documents and Settings\Administrator\桌面\新建文件夹\LPC23XX_IAR_Demo\code.lpc23xx.peripherals.iar\Common\src\lpc23xx_cstartup.s79 83
Error[40]: Bad instruction C:\Documents and Settings\Administrator\桌面\新建文件夹\LPC23XX_IAR_Demo\code.lpc23xx.peripherals.iar\Common\src\lpc23xx_cstartup.s79 85
Error[40]: Bad instruction C:\Documents and Settings\Administrator\桌面\新建文件夹\LPC23XX_IAR_Demo\code.lpc23xx.peripherals.iar\Common\src\lpc23xx_cstartup.s79 87
Error[40]: Bad instruction C:\Documents and Settings\Administrator\桌面\新建文件夹\LPC23XX_IAR_Demo\code.lpc23xx.peripherals.iar\Common\src\lpc23xx_cstartup.s79 90
Warning[24]: ENDMOD directive is ignored (only one module is allowed) C:\Documents and Settings\Administrator\桌面\新建文件夹\LPC23XX_IAR_Demo\code.lpc23xx.peripherals.iar\Common\src\lpc23xx_cstartup.s79 101
Error[73]: End-of-module missing C:\Documents and Settings\Administrator\桌面\新建文件夹\LPC23XX_IAR_Demo\code.lpc23xx.peripherals.iar\Common\src\lpc23xx_cstartup.s79 106
Error[111]: More than one module is not allowed C:\Documents and Settings\Administrator\桌面\新建文件夹\LPC23XX_IAR_Demo\code.lpc23xx.peripherals.iar\Common\src\lpc23xx_cstartup.s79 106
Error[51]: Can't be both PUBLIC and EXTERN C:\Documents and Settings\Administrator\桌面\新建文件夹\LPC23XX_IAR_Demo\code.lpc23xx.peripherals.iar\Common\src\lpc23xx_cstartup.s79 117
Error[42]: Duplicate label:'?cstartup' C:\Documents and Settings\Administrator\桌面\新建文件夹\LPC23XX_IAR_Demo\code.lpc23xx.peripherals.iar\Common\src\lpc23xx_cstartup.s79 124
Warning[24]: ENDMOD directive is ignored (only one module is allowed) C:\Documents and Settings\Administrator\桌面\新建文件夹\LPC23XX_IAR_Demo\code.lpc23xx.peripherals.iar\Common\src\lpc23xx_cstartup.s79 192
Error[109]: Expression is too complex C:\Documents and Settings\Administrator\桌面\新建文件夹\LPC23XX_IAR_Demo\code.lpc23xx.peripherals.iar\Common\src\lpc23xx_cstartup.s79 190
Error while running Assembler
Total number of errors: 24
Total number of warnings: 2
https://bbs.21ic.com/forum.php?mod=attachment&aid=MjE0OTE0fGE5MWM0ZThjfDE3NTYxNTk3NDd8MHw%3D |
