分享一下使用PSoC Creator需要注意的几个问题
 楼主| G21372 发表于 2013-11-26 21:55 | 显示全部楼层 |阅读模式
第一是:项目的路径需要放在Documents and Settings\,也就是默认的文件夹的地方,不然会报错
错误范例为:
Question:CY8CKIT-023 kit example project fails to build in PSoC Creator with the following error when run on a Parallels Desktop – “Warp.exe has encountered a problem and needs to close. We are sorry for the inconvenience” “Error: cdf.M0005: CyDsFit aborted due to errors, please address all errors and rerun CyDsFit. (App=cydsfit)”
Response: Currently, PSoC Creator does not support building a project from a network share drive. Typically, “My Documents” or equivalent folder is seen as a shared network folder by Windows running on Parallels Desktop. Please save the project in a local folder (say C:\Documents and Settings\User\...) and rebuild the example project.
第二是:KEIL需要激活 由于它是使用KEIL编译的
第三是:激活后,项目要重新写
错误范例为:
Warning L52
EVAL Version Used Before, Rebuild all *.OBJ Files
Summary   *** Warning L52
    Module: filename (module-name)
Description   The specified module has been build with a code size restricted version (Eval Version). You should rebuild all *.OBJ files of your project to ensure that no file implies code size limits for your project.
Cause   Typically this problem occurs when an Eval Version has been used before or a project was created before a license has been activated on this computer.
Resolution   Rebuild the complete project.
 楼主| G21372 发表于 2013-11-26 21:56 | 显示全部楼层
貌似以前分享过,今天遇到了同样的问题才有了感触 呵呵
happygirlwz 发表于 2013-11-27 11:27 | 显示全部楼层
呵呵,顶一下……大家共享!
acer4736 发表于 2013-11-27 13:32 | 显示全部楼层
学习了 以后有方法解决了
jxin 发表于 2013-11-27 15:45 | 显示全部楼层
第一不太懂:
我把项目放在非Documents and Settings\ 路径,貌似也没有问题啊,那个错误是说Creator目前不支持网络路径?
kk5290122 发表于 2013-11-27 22:26 | 显示全部楼层
项目路径不一定要是默认的文件夹吧,应该没有中文路径就行……
呵呵联合 发表于 2014-10-1 21:24 | 显示全部楼层
您好,
我在编译结束之后出现了这样的错误:
CyDsFit aborted due to errors,please address all errors and rerun CyDsFit
请问 这样我应该怎么解决?
首先我的存储目录不存在中文 而且我放在本地文件(C:\Documents and Settings\User\)里面依然出现同样的错误提示。
happygirlwz 发表于 2014-11-18 22:04 | 显示全部楼层
看到的第四个一样的帖子了。。。。。。
