[STM32F0] 关于STM32F030的TIM_PWM功能?(TIM3正常,TIM17不正常)
 楼主| li460135301 发表于 2014-2-19 15:56 | 显示全部楼层 |阅读模式
    我在写一个PWM功能程序,测试的时候用的是PC9引脚(TIM3CH4),产生PWM正常!
    后来我画板子的时候把PWM引脚用了PB9,也就是切换到TIM17CH1。怎么产生PWM就不正常了!不知道有没有人测试过!我用的是STM32F030R8T6。就是STM32F030 Discovery板子上测试也是这现象!
附上代码:请高手帮忙看一下是哪地方问题?感激不尽!!!
TIM3CH4的代码:
  1. //PWM_32K PIN PB8
  2. #define PWM_32K_CLOCK                  RCC_AHBPeriph_GPIOC
  3. #define PWM_32K_BASE                   GPIOC
  4. #define PWM_32K_PIN                    GPIO_Pin_9
  5. #define PWM_32K_PINSOURSE              GPIO_PinSource9
  1.   RCC_AHBPeriphClockCmd(PWM_32K_CLOCK, ENABLE);
  2.   //PWM_32K_OUTPUT
  3.   gpio.GPIO_Mode = GPIO_Mode_AF;
  4.   gpio.GPIO_Pin = PWM_32K_PIN;
  5.         //gpio.GPIO_OType = GPIO_OType_OD;
  6.   //gpio.GPIO_PuPd = GPIO_PuPd_NOPULL;
  7.         gpio.GPIO_OType = GPIO_OType_PP;
  8.   gpio.GPIO_PuPd = GPIO_PuPd_UP ;
  9.   gpio.GPIO_Speed = GPIO_Speed_50MHz;
  10.   GPIO_Init(PWM_32K_BASE, &gpio);
  11.         GPIO_PinAFConfig(PWM_32K_BASE, PWM_32K_PINSOURSE, GPIO_AF_1);
  1. //TIM3_Mode_Config PWM_32K_output
  2. static void TIM3_Mode_Config(void)
  3. {
  4.   TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
  5.   TIM_OCInitTypeDef TIM_OCInitStructure;
  6.
  7.         RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3 , ENABLE);
  8.
  9.   TIM_TimeBaseStructure.TIM_Period = 1463;
  10.   TIM_TimeBaseStructure.TIM_Prescaler = 0;
  11.
  12.   TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  13.   TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  14.   TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
  15.   TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  16.
  17.   TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  18.   TIM_OCInitStructure.TIM_Pulse = 732;
  19.   TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  20.
  21.   TIM_OC4Init(TIM3, &TIM_OCInitStructure);
  22.   TIM_OC4PreloadConfig(TIM3, TIM_OCPreload_Enable);
  23.
  24.   TIM_ARRPreloadConfig(TIM3, ENABLE);
  25.   TIM_Cmd(TIM3, DISABLE);
  26. }
切换成PB9(TIM17的代码):
  2. #define PWM_32K_CLOCK                  RCC_AHBPeriph_GPIOB
  3. #define PWM_32K_BASE                   GPIOB
  1. //TIM17_Mode_Config PWM_32K_output
  2. static void TIM17_Mode_Config(void)
  3. {
  6.
  7.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM17 , ENABLE);
  8.
  11.
  14.   TIM_TimeBaseInit(TIM17, &TIM_TimeBaseStructure);
  16.
  18.   TIM_OCInitStructure.TIM_Pulse = 732;   //F030
  20.
  21.   TIM_OC1Init(TIM17, &TIM_OCInitStructure);
  22.   TIM_OC1PreloadConfig(TIM17, TIM_OCPreload_Enable);
  23.
  24.   TIM_ARRPreloadConfig(TIM17, ENABLE);
  25.   TIM_Cmd(TIM17, DISABLE);
  26. }
  1.   //PWM_32K_OUTPUT
  2.   gpio.GPIO_Mode = GPIO_Mode_AF;
  3.   gpio.GPIO_Pin = PWM_32K_PIN;
  4.         //gpio.GPIO_OType = GPIO_OType_OD;
  5.   //gpio.GPIO_PuPd = GPIO_PuPd_NOPULL;
  6.         gpio.GPIO_OType = GPIO_OType_PP;
  7.   gpio.GPIO_PuPd = GPIO_PuPd_UP ;
  8.   gpio.GPIO_Speed = GPIO_Speed_50MHz;
  9.   GPIO_Init(PWM_32K_BASE, &gpio);
  10.         GPIO_PinAFConfig(PWM_32K_BASE, PWM_32K_PINSOURSE, GPIO_AF_2);
mmuuss586 发表于 2014-2-19 16:33 | 显示全部楼层
不同的定时器,看这句是否正确RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM17 , ENABLE);
 楼主| li460135301 发表于 2014-2-19 17:22 | 显示全部楼层
对的啊!TIM3用的是APB1,TIM17用的是APB2啊!没有错的!
   两个外设的时钟本身就不一样啊!
mmuuss586 发表于 2014-2-19 17:28 | 显示全部楼层
   两个外设的时钟本身就不一样啊! ...
那再看看用户寄存器吧。
我明天开始也调这个
我用F415:$
airwill 发表于 2014-2-19 21:04 | 显示全部楼层
TIM17CH1的PWM, 我在 F051RBT6 上测试成功. 相信 F030 肯定没有问题.
评分
参与人数 1威望 +1 收起 理由
li460135301 + 1 非常感谢!!!!
查看全部评分
 楼主| li460135301 发表于 2014-2-20 23:38 | 显示全部楼层
方便把您在F051上面的程序参考一下吗?非常感谢!!!
shi33 发表于 2015-1-26 00:48 | 显示全部楼层
遇上了一样的问题,请问你怎么解决的?
断桥残雪_98 发表于 2015-1-26 19:21 | 显示全部楼层
我也遇到这样的问题,弄了好久,还是没有出波形,哪位大侠搞定了,透露一下啊
断桥残雪_98 发表于 2015-1-26 19:50 | 显示全部楼层
遇上了一样的问题,请问你怎么解决的?
void PV_ON_Init(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOB, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
GPIO_PinAFConfig(GPIOB, GPIO_PinSource9, GPIO_AF_2);
void TIM17_PWM_Init(uint16_t period, uint16_t prescaler)
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM16|RCC_APB2Periph_TIM17, ENABLE);
TIM_TimeBaseStructure.TIM_Period = 2000;
TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
TIM_OCInitStructure.TIM_Pulse =1000;
  TIM_Cmd(TIM17, ENABLE);
TIM_CtrlPWMOutputs(TIM17, ENABLE);
我的搞定了,我的芯片是030c8t6的   好像就多了一句使能输出
airwill 发表于 2015-1-26 21:47 | 显示全部楼层
对, 我查了下我的程序, 最后还有这么一句才能输出 PWM.
TIM17->BDTR  = TIM_BDTR_MOE;
heqiaosheng 发表于 2015-7-21 15:22 | 显示全部楼层
测试成功,感谢分享!
syw467643 发表于 2015-7-22 12:00 | 显示全部楼层
STM32F030K6T6 STM32F030F4P6 STM32F030C8T6 STM030R8T6  STM8&STM32正规代理商
有技术问题或者芯片需求都可以联系我QQ1450203232  18665827861
