28027SCI发送和接收数据例程分享
 楼主| gexingyouxian 发表于 2014-2-28 20:47 | 显示全部楼层 |阅读模式
#include "DSP28x_Project.h"
extern void MemCopy(Uint16 *SourceAddr, Uint16* SourceEndAddr, Uint16* DestAddr);
extern Uint16 RamfuncsLoadStart;
extern Uint16 RamfuncsLoadEnd;
extern Uint16 RamfuncsRunStart;
void Scia_xmit(int a);
void Uart_sendstring(char * ch);
void Scia_receive(void);
int Conversion(int number, int system, char output[]);
int Sci_Receivedata;
char str[3];
void main(void) {
        char ch;
        InitSysCtrl();
        InitGpio();
        InitSpiaGpio();
        InitSciaGpio();
        DINT;
        InitPieCtrl();
        IER = 0x0000;
        IFR = 0x0000;
        InitPieVectTable();
        MemCopy(&RamfuncsLoadStart, &RamfuncsLoadEnd, &RamfuncsRunStart);
        InitFlash();
        EALLOW;
        PieVectTable.SCIRXINTA=&SCITXINTA_ISR;
        EDIS;
        PieCtrlRegs.PIEIER9.bit.INTx2=1;
        EINT;
        ERTM;
        InitSci();
        InitSpi();
        Sci_Receivedata=0x00;
        while(1)
                Scia_receive();
                if(Sci_Receivedata!=0x00)
                        ch=(char)Sci_Receivedata;
                        if(ch=='1')
                                GpioDataRegs.GPACLEAR.bit.GPIO0=1;
                        else
                                GpioDataRegs.GPASET.bit.GPIO0=1;
                        Scia_xmit(Sci_Receivedata);
                /*(void)Conversion(Sci_Receivedata,10,str);
                Uart_sendstring(str);
                Uart_sendstring("\t");*/
        while(SciaRegs.SCIFFRX.bit.RXFFST!=0)
                Sci_Receivedata=SciaRegs.SCIRXBUF.all;
    while (SciaRegs.SCIFFTX.bit.TXFFST != 0) {}
    SciaRegs.SCITXBUF=a;
        Uint16 i = 0;
    while(ch != '\0')
        Scia_xmit(ch);
        i++;
int Conversion(int number,        /*in  要转换的数据*/
               int system,        /*in  进制*/
               char output[])    /*out 输出数据*/
    // 商,余数和标记
    int Quotient, Balance, i = 0;
    int j,k;
    Quotient = number;
    do
        Balance = Quotient % system;
        output[i++] = Balance;
    } while (Quotient /= system);
    // 转换为char型
    for(j = 0; j < i; j++)
        if(output[j] > 9)
            output[j] = output[j] + 55;
        else output[j] += 48;
    // 字符串取反
    for(k = 0; k < i / 2; k++)
        char tmp;
        tmp = output[k];
        output[k] = output[i - k - 1];
        output[i - k - 1] = tmp;
    output='\0';
    return i;
void InitSci(void)
        SciaRegs.SCICCR.all=0x0007;//1个结束位,无校验位,发送8个数据位
        SciaRegs.SCICTL2.bit.TXINTENA=1;//发送中断使能
        SciaRegs.SCICTL2.bit.RXBKINTENA=1;//接受中断使能
        SciaRegs.SCIHBAUD=0x0000;
        SciaRegs.SCILBAUD=BRR9600;//波特率设置为9600
        SciaRegs.SCIFFTX.all=0xC021;//使能复位发送FIFO
        SciaRegs.SCIFFRX.all=0xC021;//使能复位接受FIFO
        SciaRegs.SCIFFCT.all=0x00;//FIFO控制寄存器延时时间位0
        SciaRegs.SCICTL1.all=0x0023;//发送/接受中断使能位
        //SciaRegs.SCIFFRX.bit.RXFFIL=7;
        SciaRegs.SCIFFTX.bit.TXFIFOXRESET=1;//重新使能发送FIFO的操作
        SciaRegs.SCIFFRX.bit.RXFIFORESET=1;//重新使能接受FIFO的操作
acer4736 发表于 2014-2-28 21:52 | 显示全部楼层
谢谢楼主分享 赞
tianli1980 发表于 2014-2-28 22:05 | 显示全部楼层
进来参考下代码,感谢楼主分享,希望有用。
zhangmangui 发表于 2014-2-28 22:35 | 显示全部楼层
还是希望更多的人能够分享
firstblood 发表于 2014-2-28 22:44 | 显示全部楼层
很不错的代码分享的,关键是编写程序的思想的啊
specialfrin 发表于 2014-2-28 22:45 | 显示全部楼层
谢谢分享 正好需要代码分享
