#define ON 1 #define OFF 0 #define LED1_Pin (1<<5) #define LED2_Pin (1<<6) #define LED3_Pin (1<<7) #define LED4_Pin (1<<8) #define LED1(a) (a==0)?(rGPBDAT |= LED1_Pin):(rGPBDAT &= ~LED1_Pin) #define LED2(a) (a==0)?(rGPBDAT |= LED2_Pin):(rGPBDAT &= ~LED2_Pin) #define LED3(a) (a==0)?(rGPBDAT |= LED3_Pin):(rGPBDAT &= ~LED3_Pin) #define LED4(a) (a==0)?(rGPBDAT |= LED4_Pin):(rGPBDAT &= ~LED4_Pin) #define KEY1 (1<<0) #define KEY2 (1<<3) #define KEY3 (1<<5) #define KEY4 (1<<6) #define KEY5 (1<<7) #define KEY6 (1<<11) void __irq IRQ_KEY(void) { unsigned int Key = 0; ClearPending(BIT_EINT8_23); rEINTPEND = 0xFFFFFF; rGPGCON &= ~((3<<14)|(3<<22)); //set gpg7 11 to input Key = rGPGDAT; if (!(Key & KEY5)) { LED1(OFF); LED2(OFF); LED3(OFF); LED4(OFF); } if (!(Key & KEY6)) { LED1(ON); LED2(ON); LED3(ON); LED4(ON); } rGPGCON |= ((2<<14)|(2<<22)); //set gpg7 11 to ENINT } void InitKey(void) { //set pins 0 3 5 6 7 11 to input rGPGCON &= ~((3<<0)|(3<<6)|(3<<10)|(3<<12)|(3<<14)|(3<<22)); //config the Key5(GPG7) and Key6(GPG11) pins to EINT mode rGPGCON &= ~((3<<14)|(3<<22)); rGPGCON |= ((2<<14)|(2<<22)); //config trigger mode rEXTINT1 |= ((U32)7<<28); //EINT15 rEXTINT1 = 0xFFFFFFFF; rEXTINT1 |= ((U32)7<<28); //EINT15 rEXTINT2 |= ((U32)7<<12); //EINT19 pISR_EINT8_23 = (unsigned int)IRQ_KEY; rEINTPEND |= (((U32)1<<15)|((U32)1<<19)); //clean pending //rEINTPEND = 0xFFFFFF; ClearPending(BIT_EINT8_23);//rSRCPND |= 0xFFFFFF; rPRIORITY = 0; rINTMOD = 0; //enable Key5(GPG7/EINT15) and Key6(GPG11/EINT19) interrupt(open marsk) rEINTMASK &= ~(((U32)1<<15)|((U32)1<<19)); rINTMSK &= ~BIT_EINT8_23; } void scan_key(void) { unsigned int Key = 0; Key = rGPGDAT; if (!(Key & KEY1)) LED1(ON); if (!(Key & KEY2)) LED2(ON); if (!(Key & KEY3)) LED3(ON); if (!(Key & KEY4)) LED4(ON); } void delay(U32 tt) { U32 i; for(;tt>0;tt--) { for(i=0;i<10000;i++){} } } int Main(int argc, char **argv) { int i; U8 key; U32 mpll_val=0; int data; mpll_val = (92<<12)|(1<<4)|(1); //init FCLK=400M, so change MPLL first ChangeMPllValue((mpll_val>>12)&0xff, (mpll_val>>4)&0x3f, mpll_val&3); ChangeClockDivider(key, 12); MMU_DisableICache(); MMU_DisableDCache(); rGPBCON = 0x155555; InitKey(); LED1(ON);LED2(ON);LED3(ON);LED4(ON); while(1) { scan_key(); delay(10); } return 0; }
举报
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
等级类勋章
发帖类勋章
时间类勋章
人才类勋章
67
452
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
