[i.MX] imx6dl的enet phy
 楼主| luozhh1018 发表于 2014-3-24 11:45 | 显示全部楼层 |阅读模式
我一个自己layout的板子上(使用imx6dl)使用了IP101A 的phy,它是GMII接口的,我已经在driver/net/phy中添加了相应的驱动,但是目前还是不能工作,提示我:
eth0: no PHY, assuming direct connection to switch
PHY 0:00 not found
eth0: could not attach to PHY
在arch/arm/mach-mx6/board_xxxx.c中的fec_data中的init的函数是实现什么样的功能,是需要怎么修改呢?(我的IO定义已经修改)
static int mx6_fec_phy_init(struct phy_device *phydev)
        unsigned short val;
        /* Ar8031 phy SmartEEE feature cause link status generates glitch,
         * which cause ethernet link down/up issue, so disable SmartEEE
        phy_write(phydev, 0xd, 0x3);
        phy_write(phydev, 0xe, 0x805d);
        phy_write(phydev, 0xd, 0x4003);
        val = phy_read(phydev, 0xe);
        val &= ~(0x1 << 8);
        phy_write(phydev, 0xe, val);
        /* To enable AR8031 ouput a 125MHz clk from CLK_25M */
        phy_write(phydev, 0xd, 0x7);
        phy_write(phydev, 0xe, 0x8016);
        phy_write(phydev, 0xd, 0x4007);
        val &= 0xffe3;
        val |= 0x18;
        /* Introduce tx clock delay */
        phy_write(phydev, 0x1d, 0x5);
        val = phy_read(phydev, 0x1e);
        val |= 0x0100;
        phy_write(phydev, 0x1e, val);
        /*check phy power*/
        val = phy_read(phydev, 0x0);
        if (val & BMCR_PDOWN)
       return 0;
static struct fec_platform_data fec_data __initdata = {
        .init = mx6_fec_phy_init,
        .phy = PHY_INTERFACE_MODE_GMII,
        //.gpio_irq = MX6_ENET_IRQ,
u-boot中又需要作些什么配置??
 楼主| luozhh1018 发表于 2014-3-24 11:47 | 显示全部楼层
sorrry,现在上一下IP101A 的datasheet
IP101ALF.pdf
351.31 KB, 下载次数: 5
FSL_TICS_Rita 发表于 2014-3-25 14:46 | 显示全部楼层
楼主你好,关于这个问题建议你到飞思卡尔官网提交一个技术服务请求,链接为:http://www.freescale.com/
