提供CPU/H264_MPEG4/USB/PCIe/SATA/3D/24bit DSP等常用IP cores
 楼主| designlab 发表于 2008-5-7 21:51 | 显示全部楼层 |阅读模式
提供CPU/H264_MPEG4/USB/PCIe/SATA/3D/2D/DDR2/DDR3/24bit&nbsp;DSP/PHY等常用IP&nbsp;cores<br />-8bit&nbsp;1T/2T/4T/12T&nbsp;MCU<br />&nbsp;&nbsp;8bit&nbsp;RISC&nbsp;CPU<br />&nbsp;&nbsp;Turbo&nbsp;186<br />&nbsp;&nbsp;V6502<br />&nbsp;&nbsp;V8086<br />&nbsp;&nbsp;16bit&nbsp;MCU<br />&nbsp;&nbsp;32bit&nbsp;RISC&nbsp;CPU&nbsp;(ARM/MIPS/ARC&nbsp;CPU)<br />&nbsp;&nbsp;IBM&nbsp;PowerPC405<br />&nbsp;&nbsp;IBM&nbsp;PowerPC440<br />&nbsp;&nbsp;IBM&nbsp;PowerPC460<br />&nbsp;&nbsp;IBM&nbsp;PowerPCPLB<br />&nbsp;&nbsp;Audio&nbsp;Echo&nbsp;Processor<br />&nbsp;&nbsp;16/24&nbsp;audio&nbsp;DSP&nbsp;Core<br />&nbsp;&nbsp;16bit&nbsp;audio&nbsp;echo&nbsp;DSP&nbsp;core<br />&nbsp;&nbsp;16bit&nbsp;audio&nbsp;DAC&nbsp;(Digital&nbsp;design&nbsp;parts)<br /><br />-&nbsp;Interface&nbsp;IP:<br />&nbsp;&nbsp;Usb1.0&nbsp;Host/Device/Hub<br />&nbsp;&nbsp;Usb1.0&nbsp;Low&nbsp;speed/Full&nbsp;speed&nbsp;PHY<br />&nbsp;&nbsp;Usb2.0&nbsp;Host/Device/OTG&nbsp;controller<br />&nbsp;&nbsp;USB2.0&nbsp;HS/OTG&nbsp;PHY&nbsp;@180nm/130nm/90nm/65nm&nbsp;(TSMC/SMIC/IBM/Charted&nbsp;process)<br />&nbsp;&nbsp;USB2.0&nbsp;mobile&nbsp;nanoPHY&nbsp;@130nm/90nm/65nm&nbsp;(TSMC/SMIC/IBM/Charted&nbsp;process)<br />&nbsp;&nbsp;Wireless&nbsp;USB&nbsp;controller/wirless&nbsp;usb&nbsp;driver<br />&nbsp;&nbsp;PCI/PCI-X<br />&nbsp;&nbsp;PCI-Express&nbsp;endpoint/rootmode/swtich&nbsp;brige&nbsp;controller<br />&nbsp;&nbsp;PCI-Express&nbsp;PHY&nbsp;@130nm/90nm/65nm&nbsp;(TSMC/SMIC&nbsp;process)<br />&nbsp;&nbsp;IEEE1394&nbsp;Controller<br />&nbsp;&nbsp;Ethernet&nbsp;10/100/1000&nbsp;Controller<br />&nbsp;&nbsp;Ethernet&nbsp;10G&nbsp;MAC&nbsp;controller&nbsp;&&nbsp;PHY<br />&nbsp;&nbsp;IDE&nbsp;controoler<br />&nbsp;&nbsp;SATA&nbsp;host/device&nbsp;Controller<br />&nbsp;&nbsp;SATA&nbsp;PHY&nbsp;&nbsp;@130nm/90nm/65nm&nbsp;(TSMC/SMIC&nbsp;process)<br />&nbsp;&nbsp;Media&nbsp;Local&nbsp;BUS&nbsp;IP<br />&nbsp;&nbsp;SD_MMC&nbsp;host&nbsp;controller&nbsp;IP<br />&nbsp;&nbsp;LCD&nbsp;controller<br />&nbsp;&nbsp;MemoryStick&nbsp;Host&nbsp;controller<br />&nbsp;&nbsp;Smart&nbsp;card&nbsp;reader<br />&nbsp;&nbsp;AMBA2.0/3.0&nbsp;IP<br />&nbsp;&nbsp;AMBA&nbsp;Interface&nbsp;IP<br />&nbsp;&nbsp;DDR2/DDR3&nbsp;memory&nbsp;controller<br />&nbsp;&nbsp;DDR2/DDR&nbsp;&nbsp;memory&nbsp;controller<br />&nbsp;&nbsp;DDR3/DDR2&nbsp;SDRAM&nbsp;PHY<br />&nbsp;&nbsp;DDR2/DDR2&nbsp;SDRAM&nbsp;PHY<br />&nbsp;&nbsp;Mobile&nbsp;Storage&nbsp;controller&nbsp;(include&nbsp;SDIO/CEVA/MMC&nbsp;host&nbsp;controller)<br />&nbsp;&nbsp;SDIO&nbsp;device&nbsp;controller<br />&nbsp;&nbsp;WLAN&nbsp;AFE&nbsp;IP<br />&nbsp;&nbsp;TSMC&nbsp;PLL<br />&nbsp;&nbsp;Arasan&nbsp;Nand&nbsp;Flash&nbsp;controller/SDIO&nbsp;device&nbsp;controller<br />&nbsp;&nbsp;CMOS&nbsp;Sensor&nbsp;Interface&nbsp;IP<br />&nbsp;&nbsp;SPDIF&nbsp;Interface&nbsp;IP<br />&nbsp;&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;<br />-&nbsp;JPEG&nbsp;Encoder/Decoder/Codec<br />&nbsp;&nbsp;Motion-JPEG<br />&nbsp;&nbsp;MPEG2&nbsp;Decoder<br />&nbsp;&nbsp;H264/MPEG4&nbsp;codec<br />&nbsp;&nbsp;H264/MPEG4&nbsp;decoder<br />&nbsp;&nbsp;H264/MPEG4&nbsp;encoder<br />&nbsp;&nbsp;H264/MPEG4&nbsp;HD&nbsp;codec<br />&nbsp;&nbsp;MPEG4&nbsp;encoder<br />&nbsp;&nbsp;2D&nbsp;graphics&nbsp;core<br />&nbsp;&nbsp;3D&nbsp;graphics&nbsp;core&nbsp;for&nbsp;PDA&nbsp;&&nbsp;audio<br />&nbsp;&nbsp;3D&nbsp;graphics&nbsp;core&nbsp;for&nbsp;wirless&nbsp;products<br />&nbsp;&nbsp;TV&nbsp;encoder&nbsp;<br />&nbsp;&nbsp;<br /><br /><br />另外还提供各种各样得synopsys&nbsp;&&nbsp;&nbsp;cadence&nbsp;&&nbsp;mentor&nbsp;&&nbsp;magma&nbsp;<br />等ASIC设计EDA平台(windows&nbsp;&&nbsp;linux&nbsp;&&nbsp;Solaris版本),有需要&nbsp;&nbsp;<br />可以email联系详细谈。<br /><br />Email:&nbsp;soft_cores@163.com<br />&nbsp;&nbsp;
 楼主| designlab 发表于 2008-5-8 21:24 | 显示全部楼层
需要的联系。
需要的联系。
