提供CPU/H264_MPEG4/USB/PCIe/SATA/3D/2D/DDR2/DDR3/24bit DSP/PHY等常用IP cores<br />-8bit 1T/2T/4T/12T MCU<br /> 8bit RISC CPU<br /> Turbo 186<br /> V6502<br /> V8086<br /> 16bit MCU<br /> 32bit RISC CPU (MIPS/ARC/ARM)<br /> IBM PowerPC405<br /> IBM PowerPC440<br /> IBM PowerPC460<br /> IBM PowerPCPLB<br /> Audio Echo Processor<br /> 16/24 audio DSP Core<br /> 16bit audio echo DSP core<br /> 16bit audio DAC (Digital design parts)<br /><br />- Interface IP:<br /> Usb1.0 Host/Device/Hub<br /> Usb1.0 Low speed/Full speed PHY<br /> Usb2.0 Host/Device/OTG controller<br /> USB2.0 HS/OTG PHY @180nm/130nm/90nm/65nm (TSMC/SMIC/IBM/Charted process)<br /> USB2.0 mobile nanoPHY @130nm/90nm/65nm (TSMC/SMIC/IBM/Charted process)<br /> Wireless USB controller/wirless usb driver<br /> PCI/PCI-X<br /> PCI-Express endpoint/rootmode/swtich brige controller<br /> PCI-Express PHY @130nm/90nm/65nm (TSMC/SMIC process)<br /> IEEE1394 Controller<br /> Ethernet 10/100/1000 Controller<br /> Ethernet 10G MAC controller & PHY<br /> IDE controoler<br /> SATA host/device Controller<br /> SATA PHY @130nm/90nm/65nm (TSMC/SMIC process)<br /> Media Local BUS IP<br /> SD_MMC host controller IP<br /> LCD controller<br /> MemoryStick Host controller<br /> Smart card reader<br /> AMBA2.0/3.0 IP<br /> AMBA Interface IP<br /> DDR2/DDR3 memory controller<br /> DDR2/DDR memory controller<br /> DDR3/DDR2 SDRAM PHY<br /> DDR2/DDR2 SDRAM PHY<br /> Mobile Storage controller (include SDIO/CEVA/MMC host controller)<br /> SDIO device controller<br /> WLAN AFE IP<br /> TSMC PLL<br /> Arasan Nand Flash controller/SDIO device controller<br /> CMOS Sensor Interface IP<br /> SPDIF Interface IP<br /> <br /> <br />- JPEG Encoder/Decoder/Codec<br /> Motion-JPEG<br /> MPEG2 Decoder<br /> H264/MPEG4 codec<br /> H264/MPEG4 decoder<br /> H264/MPEG4 encoder<br /> H264/MPEG4 HD codec<br /> MPEG4 encoder<br /> 2D graphics core<br /> 3D graphics core for PDA & audio<br /> 3D graphics core for wirless products<br /> TV encoder <br /> <br /><br /><br />另外还提供各种各样得synopsys & cadence & mentor & magma <br />等ASIC设计EDA平台(windows & linux & Solaris版本),有需要 <br />可以email联系详细谈。<br /><br />Email: soft_cores@163.com<br /> |
