[PIC®/AVR®/dsPIC®产品] dsPIC33FJ128GP706 链接出问题
 楼主| hufa123 发表于 2014-4-11 09:46 | 显示全部楼层 |阅读模式
Release build of project `D:\LKXB\LKXB.mcp' started.
Language tool versions: pic30-as.exe v3.30, pic30-gcc.exe v3.30, pic30-ld.exe v3.30, pic30-ar.exe v3.30
Fri Apr 11 09:13:39 2014
Make: The target "D:\LKXB\adcDrv1.o" is out of date.
Executing: "C:\Program Files\Microchip\mplabc30\v3.30b\bin\pic30-gcc.exe" -mcpu=33FJ128GP706 -x c -c   "SRC\adcDrv1.c" -o"adcDrv1.o" -I"D:\LKXB\H" -g -Wall
SRC\adcDrv1.c: In function 'ProcessADC_Samples_4dp':
SRC\adcDrv1.c:164: warning: control reaches end of non-void function
Make: The target "D:\LKXB\ATT7026.o" is up to date.
Make: The target "D:\LKXB\deal.o" is up to date.
Make: The target "D:\LKXB\define.o" is up to date.
Make: The target "D:\LKXB\drvi2c.o" is up to date.
Make: The target "D:\LKXB\guzhang.o" is up to date.
Make: The target "D:\LKXB\i2c_Func.o" is up to date.
Make: The target "D:\LKXB\LCD160128.o" is up to date.
Make: The target "D:\LKXB\LCDInterface.o" is up to date.
Make: The target "D:\LKXB\main.o" is up to date.
Make: The target "D:\LKXB\zimo.o" is up to date.
Make: The target "D:\LKXB\uart1Drv.o" is up to date.
Make: The target "D:\LKXB\R3223.o" is up to date.
Make: The target "D:\LKXB\OUTPUT\LKXB.cof" is out of date.
Executing: "C:\Program Files\Microchip\mplabc30\v3.30b\bin\pic30-gcc.exe" -mcpu=33FJ128GP706 "adcDrv1.o" "ATT7026.o" "deal.o" "define.o" "drvi2c.o" "guzhang.o" "i2c_Func.o" "LCD160128.o" "LCDInterface.o" "main.o" "zimo.o" "uart1Drv.o" "R3223.o" -o"D:\LKXB\OUTPUT\LKXB.cof" -Wl,-Tp33FJ128GP706.gld,--defsym=__MPLAB_BUILD=1,-Map="D:\LKXB\OUTPUT\LKXB.map",--report-mem
Program Memory  [Origin = 0x200, Length = 0x155fe]
section                    address   length (PC units)   length (bytes) (dec)
.text                        0x200               0x3ac           0x582  (1410)
.const                       0x5ac              0x1cb0          0x2b08  (11016)
.text                       0x225c              0xf532         0x16fcb  (94155)
.dinit                     0x1178e                0x50            0x78  (120)
.text                      0x117de                0x36            0x51  (81)
                     Total program memory used (bytes):        0x1a11e  (106782) 81%
Data Memory  [Origin = 0x800, Length = 0x4000]
section                    address      alignment gaps    total length  (dec)
.nbss                        0x800                   0           0x8b4  (2228)
.ndata                      0x10b4                   0             0xa  (10)
.nbss                       0x10be                   0             0x8  (8)
.ndata                      0x10c6                   0             0x4  (4)
.nbss                       0x10ca                   0             0x2  (2)
_029f4000534741c5           0x4700                   0            0x50  (80)
_03587d20534741c5           0x4750                   0            0x50  (80)
                        Total data memory used (bytes):          0x96c  (2412) 14%
Dynamic Memory Usage
region                     address                      maximum length  (dec)
heap                             0                                   0  (0)
stack                       0x10cc                              0x3634  (13876)
                        Maximum dynamic memory (bytes):         0x3634  (13876)
LCD160128.o(.text+0x568): In function `Dis_float':
D:\LKXB\SRC\LCD160128.c:358: Link Error: PC Relative branch to '___ltsf2' is out of range. Suggest large-code model.
LCD160128.o(.text+0x576):D:\LKXB\SRC\LCD160128.c:360: Link Error: PC Relative branch to '___subsf3' is out of range. Suggest large-code model.
LCD160128.o(.text+0x578):D:\LKXB\SRC\LCD160128.c: Link Error: PC Relative branch to '___fixunssfsi' is out of range. Suggest large-code model.
LCD160128.o(.text+0x592):D:\LKXB\SRC\LCD160128.c:365: Link Error: PC Relative branch to '___mulsf3' is out of range. Suggest large-code model.
LCD160128.o(.text+0x594):D:\LKXB\SRC\LCD160128.c: Link Error: PC Relative branch to '___fixunssfsi' is out of range. Suggest large-code model.
Link step failed.
Release build of project `D:\LKXB\LKXB.mcp' failed.
Fri Apr 11 09:13:47 2014
BUILD FAILED
1.这个程序比较大,提示要用大代码模式?,这怎么去设置?
2.这个程序空间才81%,编译能过,为什么链接有问题?
有谁遇到过的,帮忙指点下,谢谢
huangxz 发表于 2014-4-11 10:25 | 显示全部楼层
这个 吧
 楼主| hufa123 发表于 2014-4-11 11:22 | 显示全部楼层
是这个,能链接成功了,谢谢资深工程师,但我有还一个疑问,普通,小代码,大代码模式编译出来的东西 有什么区别?能不能提供这块资料?感谢
