(cd .libs && rm -f libsftp.la && ln -s ../libsftp.la libsftp.la)
rm -fr .libs/libhttp.a .libs/libhttp.la .libs/libhttp.lai .libs/libhttp.so
gcc -shared .libs/http-neon-method.o .libs/http-proxy.o -Wl,--whole-archive ../imported/neon/.libs/libneon.a -Wl,--no-whole-archive -Wl,--rpath -Wl,/home/dillon/imx6/L3.0.35_4.1.0_130816_source/source/ltib/rpm/BUILD/gnome-vfs-2.24.1/libgnomevfs/.libs -L/home/dillon/imx6/L3.0.35_4.1.0_130816_source/source/ltib/rootfs/usr/lib -lgmodule-2.0 -lgthread-2.0 -lgconf-2 -ldbus-glib-1 -ldbus-1 -lgobject-2.0 -lglib-2.0 -lz -lxml2 ../libgnomevfs/.libs/libgnomevfs-2.so -lutil -lrt -pthread -Wl,-soname -Wl,libhttp.so -o .libs/libhttp.so
gcc -shared .libs/ftp-method.o -Wl,--rpath -Wl,/home/dillon/imx6/L3.0.35_4.1.0_130816_source/source/ltib/rpm/BUILD/gnome-vfs-2.24.1/libgnomevfs/.libs -L/home/dillon/imx6/L3.0.35_4.1.0_130816_source/source/ltib/rootfs/usr/lib -lgmodule-2.0 -lgthread-2.0 -lgconf-2 -ldbus-glib-1 -ldbus-1 -lgobject-2.0 -lglib-2.0 -lgssapi_krb5 -lkrb5 -lk5crypto -lcom_err ../libgnomevfs/.libs/libgnomevfs-2.so -lutil -lrt -pthread -Wl,-Bsymbolic-functions -Wl,-soname -Wl,libftp.so -o .libs/libftp.so
/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/../lib/gcc/arm-fsl-linux-gnueabi/4.6.2/../../../../arm-fsl-linux-gnueabi/bin/ld: cannot find -lgssapi_krb5
/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/../lib/gcc/arm-fsl-linux-gnueabi/4.6.2/../../../../arm-fsl-linux-gnueabi/bin/ld: cannot find -lkrb5
/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/../lib/gcc/arm-fsl-linux-gnueabi/4.6.2/../../../../arm-fsl-linux-gnueabi/bin/ld: cannot find -lk5crypto
collect2: ld returned 1 exit status
make[2]: *** [libftp.la] Error 1
make[2]: *** Waiting for unfinished jobs....
rm -fr .libs/libhttp.lax
mkdir .libs/libhttp.lax
rm -fr .libs/libhttp.lax/libneon.a
mkdir .libs/libhttp.lax/libneon.a
(cd .libs/libhttp.lax/libneon.a && ar x /home/dillon/imx6/L3.0.35_4.1.0_130816_source/source/ltib/rpm/BUILD/gnome-vfs-2.24.1/modules/../imported/neon/.libs/libneon.a)
ar cru .libs/libhttp.a http-neon-method.o http-proxy.o .libs/libhttp.lax/libneon.a/ne_redirect.o .libs/libhttp.lax/libneon.a/ne_uri.o .libs/libhttp.lax/libneon.a/ne_compress.o .libs/libhttp.lax/libneon.a/ne_request.o .libs/libhttp.lax/libneon.a/ne_basic.o .libs/libhttp.lax/libneon.a/ne_md5.o .libs/libhttp.lax/libneon.a/ne_props.o .libs/libhttp.lax/libneon.a/ne_207.o .libs/libhttp.lax/libneon.a/ne_utils.o .libs/libhttp.lax/libneon.a/ne_xml.o .libs/libhttp.lax/libneon.a/ne_string.o .libs/libhttp.lax/libneon.a/ne_dates.o .libs/libhttp.lax/libneon.a/ne_locks.o .libs/libhttp.lax/libneon.a/ne_session.o .libs/libhttp.lax/libneon.a/ne_gnomevfs.o .libs/libhttp.lax/libneon.a/ne_auth.o .libs/libhttp.lax/libneon.a/ne_alloc.o .libs/libhttp.lax/libneon.a/ne_xmlreq.o .libs/libhttp.lax/libneon.a/ne_acl.o
arm-linux-ranlib .libs/libhttp.a
creating libhttp.la
(cd .libs && rm -f libhttp.la && ln -s ../libhttp.la libhttp.la)
make[2]: Leaving directory `/home/dillon/imx6/L3.0.35_4.1.0_130816_source/source/ltib/rpm/BUILD/gnome-vfs-2.24.1/modules'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/dillon/imx6/L3.0.35_4.1.0_130816_source/source/ltib/rpm/BUILD/gnome-vfs-2.24.1'
make: *** [all] Error 2
error: Bad exit status from /home/dillon/imx6/L3.0.35_4.1.0_130816_source/source/ltib/tmp/rpm-tmp.35091 (%build)
RPM build errors:
Build time for gnome-vfs: 21 seconds
Failed building gnome-vfs
f_buildrpms() returned an error, exiting
traceback:
main:572
Started: Wed Apr 16 10:22:09 2014
Ended: Wed Apr 16 10:22:32 2014
Elapsed: 23 seconds
These packages failed to build:
gnome-vfs
Build Failed
Exiting on error or interrupt
提示缺少
这个该怎么解决啊? :( |
