谢谢您的回复,我按您的提示查看了手册,发现是这样描述的:
15.1.1 Glossary
Command Write Sequence — An MCU instruction sequence to execute built-in algorithms (including
program and erase) on the Flash memory.
D-Flash Memory — The D-Flash memory constitutes the nonvolatile memory store for data.
D-Flash Sector—The D-Flash sector is the smallest portion of the D-Flash memory that can be erased.
The D-Flash sector consists of four 64 byte rows for a total of 256 bytes.
NVMCommand Mode—AnNVMmode using the CPU to setup the FCCOB register to pass parameters
required for Flash command execution.
Phrase — An aligned group of four 16-bit words within the P-Flash memory. Each phrase includes two
sets of aligned double words with each set including 7 ECC bits for single bit fault correction and double
bit fault detection within each double word.
P-Flash Memory—The P-Flash memory constitutes the main nonvolatile memory store for applications.
P-Flash Sector — The P-Flash sector is the smallest portion of the P-Flash memory that can be erased.
Each P-Flash sector contains 512 bytes.
Program IFR — Nonvolatile information register located in the P-Flash block that contains the Device
ID, Version ID, and the Program Once field.
