添加API的Lib后报错怎么办
 楼主| meishizhaoshi 发表于 2014-4-30 22:16 | 显示全部楼层 |阅读模式
在做Ti2808的在线烧录,添加API的lib后,系统编译报错,开始找不到lib,后来把lib拷到了cgtool那边的文件夹里
cmd文件添加
   /* Allocate program areas: */
   Flash28_API:
        -lFlash2808_API_V302.lib(.econst)
        -lFlash2808_API_V302.lib(.text)
   }                   LOAD = FLASHD,
                       RUN = RAML0,
                       LOAD_START(_Flash28_API_LoadStart),
                       LOAD_END(_Flash28_API_LoadEnd),
                       RUN_START(_Flash28_API_RunStart),
                       PAGE = 0
编译后,
[Linking...] "C:\CCStudio_v3.3\C2000\cgtools\bin\cl2000" -@"Debug.lkf"
<Linking>
>> E:\03_Bootloader\V21_2808_Basic\cmd\PV2808_FLASH.cmd, line 134: warning:
               C:/CCStudio_v3.3/C2000/cgtools/lib/Flash2808_API_V302.lib(.econst) not found
>> E:\03_Bootloader\V21_2808_Basic\cmd\PV2808_FLASH.cmd, line 135: warning:
               C:/CCStudio_v3.3/C2000/cgtools/lib/Flash2808_API_V302.lib(.text)
               not found
>> warning: load address of uninitialized section Flash28_API ignored
>> warning: can't find a memory area named 'RAML0' on page 0 for allocation of
            'Flash28_API'
>>   error: can't find any memory areas for allocation of 'Flash28_API'
>>   error: can't allocate 'Flash28_API' into 'RAML0' (page 0)
>>   error: errors in input - ./Debug/PV12K.out not built
 楼主| meishizhaoshi 发表于 2014-4-30 22:17 | 显示全部楼层
重新修改了,只剩下warning
这个warning要管吗?
<Linking>
               not found
Build Complete,
  0 Errors, 3 Warnings, 0 Remarks.
zhangmangui 发表于 2014-5-3 10:37 | 显示全部楼层
重新修改了,只剩下warning
这个warning要管吗?
[Linking...] "C:\CCStudio_v3.3\C2000\cgtools\bin\cl200 ...
你看看cmd中 应该给警告提示的这些段没有分配空间
应该关系不大   CCS会给自动分配必要段的空间
拿起书本 发表于 2014-6-5 17:34 | 显示全部楼层
这个问题双前也遇到过,具体原因忘记了,路径没对应包含?!
