[STM8] STM8L PWM输出问题
 楼主| tiantangwuzhe 发表于 2014-4-30 23:33 | 显示全部楼层 |阅读模式
/*使用定时器1的通道1输出PWM*/
void TIM1_PWM_Initial(void)
  TIM1_DeInit();
  TIM1_TimeBaseInit(0x0000, TIM1_CounterMode_Up, 500, 0x01);
  TIM1_OC1Init(TIM1_OCMode_PWM1,
               TIM1_OutputState_Enable,
               TIM1_OutputNState_Disable,
               200,//占空比
               TIM1_OCPolarity_High,
               TIM1_OCNPolarity_High,
               TIM1_OCIdleState_Set,
               TIM1_OCNIdleState_Set);
  TIM1_OC1PreloadConfig(ENABLE);
  TIM1_Cmd(ENABLE);
    TIM1->BKR |=0x80;//主使能
void main(void)
  CLK_HSICmd(ENABLE);
  TIM1_PWM_Initial();
  /* Executive loop, runs continually after initialization */
  while (1)
gufeng1 发表于 2014-5-1 12:08 | 显示全部楼层
和刚才那个一样的吧
mmuuss586 发表于 2014-5-1 13:48 | 显示全部楼层
什么问题呢???
mmuuss586 发表于 2014-5-1 13:49 | 显示全部楼层
没输出,还是其它啥问题?
mmuuss586 发表于 2014-5-1 14:21 | 显示全部楼层
你GPIO未设置吧
static void TIM2_Config(void)
  /* Enable TIM2 clock */
  CLK_PeripheralClockConfig(CLK_Peripheral_TIM2, ENABLE);
  /* Config TIM2 Channel 1 and channel 2 pins */
  GPIO_Init(GPIOB, GPIO_Pin_0 | GPIO_Pin_2, GPIO_Mode_Out_PP_High_Fast);
  /* Time base configuration */
  TIM2_TimeBaseInit(TIM2_Prescaler_1, TIM2_CounterMode_Up, 65535);
  /* PWM1 Mode configuration: Channel1 */
  TIM2_OC1Init(TIM2_OCMode_PWM1, TIM2_OutputState_Enable, CCR1_Val, TIM2_OCPolarity_High, TIM2_OCIdleState_Set);
  TIM2_OC1PreloadConfig(ENABLE);
  /* PWM1 Mode configuration: Channel2 */
  TIM2_OC2Init(TIM2_OCMode_PWM1, TIM2_OutputState_Enable,CCR2_Val, TIM2_OCPolarity_High, TIM2_OCIdleState_Set);
  TIM2_OC2PreloadConfig(ENABLE);
  TIM2_ARRPreloadConfig(ENABLE);
  /* Enable TIM2 outputs */
  TIM2_CtrlPWMOutputs(ENABLE);
  /* TIM2 enable counter */
  TIM2_Cmd(ENABLE);
 楼主| tiantangwuzhe 发表于 2014-5-3 01:13 来自手机 | 显示全部楼层
你GPIO未设置吧
谢谢,是没有设置IO
mmuuss586 发表于 2014-5-3 08:40 | 显示全部楼层
谢谢,是没有设置IO
:D
看样子解决了
aiwosuoai1992 发表于 2016-11-15 11:26 | 显示全部楼层
你GPIO未设置吧
找了很多例程,还是你的最好用,感谢
qiuwenjie 发表于 2020-6-29 14:30 | 显示全部楼层
你GPIO未设置吧
看了这么多历程,就你的没问题,专门登录感谢
