2812FLASH运行速度慢问题
 楼主| jxmzzr 发表于 2014-5-7 10:43 | 显示全部楼层 |阅读模式
flash, AI, AN, ST, TI
2812硬件仿真速度较快,但下载到FLASH中运行速度下降10倍左右,可能初始设置有问题,请高手帮忙.
void InitFlash(void)
  EALLOW;
  //Enable Flash Pipeline mode to improve performance
  //of code executed from Flash.
  FlashRegs.FOPT.bit.ENPIPE = 1;
   //Set the Random Waitstate for the Flash
  FlashRegs.FBANKWAIT.bit.RANDWAIT = 5;
  //Set the Paged Waitstate for the Flash
  FlashRegs.FBANKWAIT.bit.PAGEWAIT = 5;
   //Set number of cycles to transition from sleep to standby
  FlashRegs.FSTDBYWAIT.bit.STDBYWAIT = 0x01FF;
  //Set number of cycles to transition from standby to active
  FlashRegs.FACTIVEWAIT.bit.ACTIVEWAIT = 0x01FF;
  EDIS;
  asm(" RPT #7 || NOP";
void InitPll(Uint16 val)
  volatile Uint16 iVol;
   EALLOW;
   SysCtrlRegs.PLLCR.bit.DIV = 6;
   /////////////////////////////add
   XintfRegs.XINTCNF2.bit.CLKOFF=1 ;//off clkout
    XintfRegs.XINTCNF2.bit.WRBUFF=3 ;//
    XintfRegs.XINTCNF2.bit.CLKMODE=0;//
     XintfRegs.XINTCNF2.bit.XTIMCLK=0;//=sysclk
    SysCtrlRegs.HISPCP.all = 0x0007; //low clk
    SysCtrlRegs.LOSPCP.all = 0x0007; //low clk
   EDIS;
     for(iVol= 0; iVol< ( (131072/2)/12 ); iVol++)
wangdezhi 发表于 2014-5-7 17:17 | 显示全部楼层
仿真在ram里面吧
仿真不在flash吧
zhangmangui 发表于 2014-5-7 22:32 | 显示全部楼层
这个问题大家讨论了很多次了   flash的速度肯定是无法和RAM比的
flash的效率一般只有RAM的70-80%左右
你可以采用Flash搬移到Ram中运行
