Verilog程序转为VHDL求帮忙
 楼主| a13251195 发表于 2014-5-29 17:59 | 显示全部楼层 |阅读模式
Verilog程序转为VHDL求帮忙
module keyinput (
        input wire clk,
        input wire rst,
        input wire [3:0] row,
        output reg [3:0] col,
        output reg [7:0] qout,
        output reg [2:0] sel,
        output reg cs,
        output reg beep,
        output reg led,
        input wire setpsw,
        input unlock
reg [7:0] keypad = 8'h00;
reg [4:0] keycode = 5'h10;
reg [3:0] keystate1 = 4'hf;
reg [3:0] keystate2 = 4'hf;
reg keypressdone = 1'b1;
reg [4:0] keycode1 = 5'h10;
reg [4:0] keycode2 = 5'h10;
reg [4:0] keycode3 = 5'h10;
reg [3:0] row1;
reg [3:0] row2;
reg [3:0] row3;
reg [4:0] ledmsk = 5'h0;
reg [15:0] lednum = 16'h0000;
reg [1:0] dotpint = 2'd0;
reg [15:0] psw=16'h1316;
reg [27:0] cnt = 28'd0;
reg pswflag=0;
reg [4:0]pswcnt=0;
reg temp1=1;
reg temp2=1;
reg temp3=1;
reg temp4=1;
always @ (posedge clk)
        cnt = cnt + 1'b1;
cs=1;
always @ (posedge cnt[20])        begin
   beep =1;
        case (col[3:0])
                4'b1110: col[3:0] <= 4'b1101;
                4'b1101: col[3:0] <= 4'b1011;
                4'b1011: col[3:0] <= 4'b0111;
                4'b0111: col[3:0] <= 4'b1110;
                default: col[3:0] <= 4'b1110;
                endcase
        keypad[7:4] = row[3:0];
        keypad[3:0] = col[3:0];
        case (keypad[7:0])
                8'b11101110: keycode[4:0] = 5'h0;
                8'b11101101: keycode[4:0] = 5'h4;
                8'b11101011: keycode[4:0] = 5'h8;
                8'b11100111: keycode[4:0] = 5'hc;
                8'b11011110: keycode[4:0] = 5'h1;
                8'b11011101: keycode[4:0] = 5'h5;
                8'b11011011: keycode[4:0] = 5'h9;
                8'b11010111: keycode[4:0] = 5'hd;
                8'b10111110: keycode[4:0] = 5'h2;
                8'b10111101: keycode[4:0] = 5'h6;
                8'b10111011: keycode[4:0] = 5'ha;
                8'b10110111: keycode[4:0] = 5'he;
                8'b01111110: keycode[4:0] = 5'h3;
                8'b01111101: keycode[4:0] = 5'h7;
                8'b01111011: keycode[4:0] = 5'hb;
                8'b01110111: keycode[4:0] = 5'hf;
                default: keycode[4:0] = 5'h10;
                endcase
        if(rst) begin
                                        keycode1<=keycode;
                                        keycode2<=keycode1;
                                        keycode3<=keycode2;
                                        row1 <= row;
                                        row2<= row1;
                                        row3<=row2;
                                        if((row3 < 4'b1111)&&(row2 == 4'b1111)&&(row1==4'b1111)&&(row == 4'b1111))
                                                begin
                                                 if(keycode3 != keycode)//&& (keycode2 == keycode3))
                                                        begin
        lednum[15:0] = lednum[15:0] << 4;
                                        lednum[3:0] = keycode3[3:0];
                                                        end
                                                end
        end
        else
        begin
        lednum[15:0]=16'h0000;
        pswflag=0;
        led=0;
        end
        temp1<=unlock;
        temp2<=temp1;
        temp3<=temp2;
        temp4<=temp3;
        if({temp4,temp3,temp2,temp1}==4'b1100)
        begin
        if(lednum==psw)
                        begin
                        led=1;
                        pswflag=1;
                        pswcnt<=0;
                        end
                        else
                        begin
                        led=0;
                        pswcnt<=pswcnt+1;
                        end
                end
                if(pswflag==1)
                begin
                        if(!setpsw)
                        begin
                                psw=lednum;
                                pswflag=0;
                                end
                end
                                if(pswcnt>=3)
                                        beep=0;
   end
always @ (negedge cnt[16]) begin
        case (sel)
                default: begin
                        sel = 3'b111;
                        ledmsk[3:0] = lednum[3:0];
                         qout[7] = 1'b0;
                        end
                3'b100: begin
                                                        sel = 3'b111;
                                                        end
                3'b111: begin
                        sel = 3'b110;
                        ledmsk[3:0] = lednum[7:4];
                         qout[7] = 1'b0;
                        end
                3'b110: begin
                        sel = 3'b101;
                        ledmsk[3:0] = lednum[11:8];
                         qout[7] = 1'b0;
                        end
                3'b101: begin
                        sel = 3'b100;
                        ledmsk[3:0] = lednum[15:12];
                        qout[7] = 1'b0;
                        end
                endcase
        case (ledmsk)
                5'h0: qout[6:0] = 7'b0111111;
                5'h1: qout[6:0] = 7'b0000110;
                5'h2: qout[6:0] = 7'b1011011;
                5'h3: qout[6:0] = 7'b1001111;
                5'h4: qout[6:0] = 7'b1100110;
                5'h5: qout[6:0] = 7'b1101101;
                5'h6: qout[6:0] = 7'b1111101;
                5'h7: qout[6:0] = 7'b0000111;
                5'h8: qout[6:0] = 7'b1111111;
                5'h9: qout[6:0] = 7'b1101111;
                5'hA: qout[6:0] = 7'b1110111;
                5'hB: qout[6:0] = 7'b1111100;
                5'hC: qout[6:0] = 7'b0111001;
                5'hD: qout[6:0] = 7'b1011110;
                5'hE: qout[6:0] = 7'b1111001;
                5'hF: qout[6:0] = 7'b1110001;
                default: qout[6:0] = 7'b0000000;
                endcase
        end
endmodule
