[i.MX] imx6_platform_sdk_v1.1.0编译出错
 楼主| xhh4u1986 发表于 2014-6-17 13:19 | 显示全部楼层 |阅读模式
Administrator@MPCY5KGVYFF66US /xhh/iMX6_Platform_SDK
$ ./tools/build_sdk -clean -target=all -test vpu
Deleting output directory...
done.
Building sdk [mx6dq sabre_ai a]
Compiling sdk/drivers/accelerometer/src/mma8451.c
make[2]: flock:命令未找到
/xhh/iMX6_Platform_SDK/mk/targets.mk:173: recipe for target `/xhh/iMX6_Platform_SDK/output/mx6dq/lib/libsdk.a(/xhh/iMX6_Platform_SDK/output/mx6dq/lib/obj/sdk/sdk/drivers/accelerometer/src/mma8451.o)' failed
make[2]: *** [/xhh/iMX6_Platform_SDK/output/mx6dq/lib/libsdk.a(/xhh/iMX6_Platform_SDK/output/mx6dq/lib/obj/sdk/sdk/drivers/accelerometer/src/mma8451.o)] Error 127
/xhh/iMX6_Platform_SDK/mk/targets.mk:186: recipe for target `drivers' failed
make[1]: *** [drivers] Error 2
mk/targets.mk:186: recipe for target `sdk' failed
make: *** [sdk] Error 2
Build mx6dq sabre_ai rev_a vpu failed with return code 2!
FSL_TICS_Rita 发表于 2014-6-20 18:10 | 显示全部楼层
楼主你好,关于 imx6_platform_sdk_v1.1.0的使用,建议你参考里面的说明文档来操作的哦。
