hub 2-1:1.0: USB hub found
hub 2-1:1.0: 4 ports detected
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
Bus freq driver module loaded
Bus freq driver Enabled
mxc_dvfs_core_probe
DVFS driver module loaded
mmcblk0: p1 p2 p3 < p5 p6 p7 p8 > p4
regulator_init_complete: PFUZE100_VGEN6: incomplete constraints, leaving on
regulator_init_complete: PFUZE100_VGEN3: incomplete constraints, leaving on
regulator_init_complete: PFUZE100_VGEN2: incomplete constraints, leaving on
regulator_init_complete: PFUZE100_VGEN1: incomplete constraints, leaving on
snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 02:41:40 UTC (9700)
mmcblk0: p4 size 5554176 extends beyond EOD, truncated
eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=1:01, irq=-1)
mmcblk0boot1: unknown partition table
mmcblk0boot0: unknown partition table
mmc1: card claims to support voltages below the defined range. These will be ignored.
mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
mmc1: new SDIO card at address 0001
mmc2: new high speed SDHC card at address 1234
mmcblk1: mmc2:1234 SA04G 3.63 GiB
mmcblk1: p1
usb 2-1.1: new low speed USB device number 3 using fsl-ehci
input: HID 0b38:0010 as /devices/platform/fsl-ehci.1/usb2/2-1/2-1.1/2-1.1:1.0/input/input5
generic-usb 0003:0B38:0010.0001: input,hidraw0: USB HID v1.10 Keyboard [HID 0b38:0010] on usb-fsl-ehci.1-1.1/input0
input: HID 0b38:0010 as /devices/platform/fsl-ehci.1/usb2/2-1/2-1.1/2-1.1:1.1/input/input6
generic-usb 0003:0B38:0010.0002: input,hidraw1: USB HID v1.10 Device [HID 0b38:0010] on usb-fsl-ehci.1-1.1/input1
PHY: 1:01 - Link is Up - 100/Full
Sending DHCP requests ., OK
IP-Config: Got DHCP answer from 0.0.0.0, my address is 192.168.0.101
IP-Config: Complete:
device=eth0, addr=192.168.0.101, mask=255.255.255.0, gw=192.168.0.1,
host=192.168.0.101, domain=, nis-domain=(none),
bootserver=0.0.0.0, rootserver=192.168.0.114, rootpath=
<6>VFS: Mounted root (nfs filesystem) on device 0:13.
devtmpfs: mounted
Freeing init memory: 208K
* Starting mDNS/DNS-SD daemon [ OK ]
* Starting network connection manager [ OK ]
* Starting configure network device [ OK ]
* Starting Userspace bootsplash [ OK ]
* Starting configure network device security [ OK ]
启动一、就一直卡死到这儿了。怎么一回事? |
