[Atmel] AVR32UC技术参考手册
 楼主| ddllxxrr 发表于 2014-7-4 12:04 | 显示全部楼层 |阅读模式
AVR, TI, AN, ic, IO
AVR32 is a new high-performance 32-bit RISC microprocessor core, designed for cost-sensitive embedded applications, with particular emphasis on low power consumption and high code density. In addition, the instruction set architecture has been tuned to allow for a variety of microarchitectures, enabling the AVR32 to be implemented as low-, mid- or high-performance processors. AVR32 extends the AVR family into the world of 32- and 64-bit applications.
2404
