[STM32] STM32 F207CAN 通信问题 求大神
 楼主| a374940197 发表于 2014-7-8 21:23 | 显示全部楼层 |阅读模式
#include "stm32f2xx.h"
#include "stm32f2xx_rcc.h"
#define  uchar unsigned char
USART_InitTypeDef USART_InitStructure;
uchar send[7]={'m','e','n','g','n','a','n'};
/* Exported types ------------------------------------------------------------*/
/* Exported constants --------------------------------------------------------*/
#define USE_CAN1
/* #define USE_CAN2 */
#ifdef  USE_CAN1
  #define CANx                       CAN1
  #define CAN_CLK                    RCC_APB1Periph_CAN1
  #define CAN_RX_PIN                 GPIO_Pin_0
  #define CAN_TX_PIN                 GPIO_Pin_1
  #define CAN_GPIO_PORT              GPIOD
  #define CAN_GPIO_CLK               RCC_AHB1Periph_GPIOD
  #define CAN_AF_PORT                GPIO_AF_CAN1
  #define CAN_RX_SOURCE              GPIO_PinSource0
  #define CAN_TX_SOURCE              GPIO_PinSource1
#else /*USE_CAN2*/
  #define CANx                       CAN2
  #define CAN_CLK                    (RCC_APB1Periph_CAN1 | RCC_APB1Periph_CAN2)
  #define CAN_RX_PIN                 GPIO_Pin_5
  #define CAN_TX_PIN                 GPIO_Pin_6
  #define CAN_GPIO_PORT              GPIOB
  #define CAN_GPIO_CLK               RCC_AHB1Periph_GPIOB
  #define CAN_AF_PORT                GPIO_AF_CAN2
  #define CAN_RX_SOURCE              GPIO_PinSource5
  #define CAN_TX_SOURCE              GPIO_PinSource6
#endif  /* USE_CAN1 */
/* Exported macro ------------------------------------------------------------*/
/* Exported functions ------------------------------------------------------- */
//void LED_Display(uint8_t Ledstatus);
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
//#define KEY_PRESSED     0x00
//#define KEY_NOT_PRESSED 0x01
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
CAN_InitTypeDef        CAN_InitStructure;
CAN_FilterInitTypeDef  CAN_FilterInitStructure;
CanTxMsg TxMessage;
CanRxMsg RxMessage;
unsigned char rcv[8]={0};
/* Private function prototypes -----------------------------------------------*/
void NVIC_Config(void);
void CAN_Config(void);
void Init_RxMes(CanRxMsg *RxMessage);
void Delay(void);
void Uart2Init(void);
/* Private functions ---------------------------------------------------------*/
  * @brief  Main program.
  * @param  None
  * @retval None
/*void CAN1_RX0_IRQHandler(void)
          CanRxMsg RxMessage;
    int i = 0;
    int u8_RxLen = 0;
    RxMessage.StdId = 0x00;
    RxMessage.ExtId = 0x00;
    RxMessage.IDE = 0;
    RxMessage.RTR = 0;
    RxMessage.DLC = 0;
    RxMessage.FMI = 0;
    for( i=0;i<8;i++){
        RxMessage.Data=0x00;
    CAN_Receive(CAN1, CAN_FIFO0, &RxMessage);
    u8_RxLen = RxMessage.DLC;
        for( i=0;i<u8_RxLen; i++){
            rcv[u8_RxLen] = RxMessage.Data[u8_RxLen];
         CAN_ClearITPendingBit(CAN1,CAN_IT_FMP0);
         CAN_FIFORelease(CAN1,CAN_FIFO0);
int main(void)
          int i;
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f2xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f2xx.c file
  CAN_Config();
  /* NVIC configuration */
  NVIC_Config();
  Init_RxMes(&RxMessage);
  Uart2Init();       //初始化串口
/*Configure Push button key */
/*STM_EVAL_PBInit(BUTTON_KEY, BUTTON_MODE_GPIO);*/
while(1){
        /* 等待发送完成 */
//        while((CAN_TransmitStatus(CAN1,TransmitMailbox) != CANTXOK));
//        for(i=0;i<=8;i++)
//         sendchar(TxMessage.Data);
          /* 等待接收完成 */
        while((CAN_MessagePending(CAN1,CAN_FIFO0) == 0))
        CAN_Receive(CAN1,CAN_FIFO0,&RxMessage);;
           /* 接收数据 */
//           if(CAN_MessagePending(CAN1,CAN_FIFO0)){
                for(i=0;i<=8;i++)
         sendchar(RxMessage.Data);
//        printf("\n\rUSART Printf Example: retarget the C library printf function to the USART\n\r");
//  RxMessage.IDE=1;
  /* Infinite loop */
       RxMessage.StdId=0x00;
       RxMessage.IDE=CAN_ID_STD;
       RxMessage.DLC=0;
       RxMessage.Data[0]=0x00;
       RxMessage.Data[1]=0x00;
           RxMessage.Data[2]=0x00;
           RxMessage.Data[3]=0x00;
           RxMessage.Data[4]=0x00;
           RxMessage.Data[5]=0x00;
           RxMessage.Data[6]=0x00;
           RxMessage.Data[7]=0x00;
           if (CAN_MessagePending(CAN1,CAN_FIFO0)){
       CAN_Receive(CAN1,CAN_FIFO0, &RxMessage);
//      Delay();
         for(i=0;i<=7;i++){
             send=RxMessage.Data;
         for(i=0;i<=7;i++)
         { sendchar(send);
  * @brief  Configures the CAN.
  * @param  None
  * @retval None
        GPIO_InitTypeDef GPIO_InitStructure1;
        USART_InitStructure.USART_BaudRate = 115200;
          USART_InitStructure.USART_WordLength = USART_WordLength_8b;
          USART_InitStructure.USART_StopBits = USART_StopBits_1;
          USART_InitStructure.USART_Parity = USART_Parity_No;
          USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
          USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
        RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE);
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2, ENABLE);
        GPIO_PinAFConfig(GPIOD, GPIO_PinSource5, GPIO_AF_USART2);
        GPIO_PinAFConfig(GPIOD, GPIO_PinSource6, GPIO_AF_USART2);
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
          GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
          GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;
          GPIO_Init(GPIOD, &GPIO_InitStructure);
          GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
        USART_Init(USART2, &USART_InitStructure);
        USART_Cmd(USART2, ENABLE);
        GPIO_InitStructure1.GPIO_Pin = GPIO_Pin_13;
    GPIO_InitStructure1.GPIO_Mode = GPIO_Mode_OUT;
    GPIO_InitStructure1.GPIO_OType = GPIO_OType_PP;
    GPIO_InitStructure1.GPIO_PuPd = GPIO_PuPd_UP;
    GPIO_InitStructure1.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_Init(GPIOD, &GPIO_InitStructure1);
  GPIO_InitTypeDef  GPIO_InitStructure;
  /* CAN GPIOs configuration **************************************************/
  /* Enable GPIO clock */
  RCC_AHB1PeriphClockCmd(CAN_GPIO_CLK, ENABLE);
  /* Connect CAN pins to AF9 */
  GPIO_PinAFConfig(CAN_GPIO_PORT, CAN_RX_SOURCE, CAN_AF_PORT);
  GPIO_PinAFConfig(CAN_GPIO_PORT, CAN_TX_SOURCE, CAN_AF_PORT);
  /* Configure CAN RX and TX pins */
  GPIO_InitStructure.GPIO_Pin = CAN_RX_PIN|CAN_TX_PIN;
  GPIO_Init(CAN_GPIO_PORT, &GPIO_InitStructure);
  /* CAN configuration ********************************************************/
  /* Enable CAN clock */
  RCC_APB1PeriphClockCmd(CAN_CLK, ENABLE);
  /* CAN register init */
  CAN_DeInit(CANx);
  /* CAN cell init */
  CAN_InitStructure.CAN_TTCM = DISABLE;
  CAN_InitStructure.CAN_ABOM = DISABLE;
  CAN_InitStructure.CAN_AWUM = DISABLE;
  CAN_InitStructure.CAN_NART = DISABLE;
  CAN_InitStructure.CAN_RFLM = DISABLE;
  CAN_InitStructure.CAN_TXFP = DISABLE;
  CAN_InitStructure.CAN_Mode = CAN_Mode_Normal;
  CAN_InitStructure.CAN_SJW = CAN_SJW_1tq;
  /* CAN Baudrate = 1MBps (CAN clocked at 30 MHz) */
  CAN_InitStructure.CAN_BS1 = CAN_BS1_6tq;
  CAN_InitStructure.CAN_BS2 = CAN_BS2_8tq;
  CAN_InitStructure.CAN_Prescaler = 2;
  CAN_Init(CANx, &CAN_InitStructure);
  /* CAN filter init */
#ifdef  USE_CAN1
  CAN_FilterInitStructure.CAN_FilterNumber = 0;
#else /* USE_CAN2 */
  CAN_FilterInitStructure.CAN_FilterNumber = 14;
  CAN_FilterInitStructure.CAN_FilterMode = CAN_FilterMode_IdMask;
  CAN_FilterInitStructure.CAN_FilterScale = CAN_FilterScale_32bit;
  CAN_FilterInitStructure.CAN_FilterIdHigh = 0x0000;
  CAN_FilterInitStructure.CAN_FilterIdLow = 0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdHigh = 0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdLow = 0x0000;
  CAN_FilterInitStructure.CAN_FilterFIFOAssignment = 0;
  CAN_FilterInitStructure.CAN_FilterActivation = ENABLE;
  CAN_FilterInit(&CAN_FilterInitStructure);
  /* Transmit Structure preparation */
  TxMessage.StdId = 0x321;
  TxMessage.ExtId = 0x01;
  TxMessage.RTR = CAN_RTR_DATA;
  TxMessage.IDE = CAN_ID_STD;
  TxMessage.DLC = 1;
  /* Enable FIFO 0 message pending Interrupt */
  CAN_ITConfig(CANx, CAN_IT_FMP0, ENABLE);
  * @brief  Configures the NVIC for CAN.
  * @param  None
  * @retval None
  NVIC_InitTypeDef  NVIC_InitStructure;
#ifdef  USE_CAN1
  NVIC_InitStructure.NVIC_IRQChannel = CAN1_RX0_IRQn;
  NVIC_InitStructure.NVIC_IRQChannel = CAN2_RX0_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  * @brief  Initializes the Rx Message.
  * @param  RxMessage: pointer to the message to initialize
  * @retval None
  uint8_t i = 0;
  RxMessage->StdId = 0x00;
  RxMessage->ExtId = 0x00;
  RxMessage->IDE = CAN_ID_STD;
  RxMessage->DLC = 0;
  RxMessage->FMI = 0;
  for (i = 0;i < 8;i++)
    RxMessage->Data = 0x00;
  * @brief  Turn ON/OFF the dedicated led
  * @param  Ledstatus: Led number from 0 to 3.
  * @retval None
/*void LED_Display(uint8_t Ledstatus)
  /* Turn off all leds */
/* STM_EVAL_LEDOff(LED1);
  STM_EVAL_LEDOff(LED2);
  STM_EVAL_LEDOff(LED3);
  STM_EVAL_LEDOff(LED4);
  switch(Ledstatus)
    case(1):
      STM_EVAL_LEDOn(LED1);
      break;
    case(2):
      STM_EVAL_LEDOn(LED2);
      break;
    case(3):
      STM_EVAL_LEDOn(LED3);
      break;
    case(4):
      STM_EVAL_LEDOn(LED4);
      break;
    default:
      break;
  * @brief  Delay
  * @param  None
  * @retval None
void Delay(void)
  uint16_t nTime = 0x0000;
  for(nTime = 0; nTime <0xFFF; nTime++)
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
int sendchar (int c) {
  if (c == '\n')
          while (!(USART2->SR & 0x0080));
          USART2->DR = 0x0D;
  USART2->DR = (c & 0x1FF);
  return (c);
程序如上   用的是飞思卡尔单片机给它发数据 但是收不到数据  求大神指教。
 楼主| a374940197 发表于 2014-7-8 21:26 | 显示全部楼层
小弟刚入门  求大神指导  十分感谢
 楼主| a374940197 发表于 2014-7-8 21:28 | 显示全部楼层
飞思卡尔的波特率是1MBHZ  但是别的参数不一致。   主要这程序是否正确
airwill 发表于 2014-7-9 07:50 | 显示全部楼层
大体看了一下, 波特率, 时钟, 引脚配置都可以.
这种硬件底层调试, 接调试器跟踪, 分析硬件寄存器来差错吧
