[技术求助] DAC8760
 楼主| 流星在颤抖 发表于 2014-7-19 17:21 | 显示全部楼层 |阅读模式
有哪位大神用过DAC8760的,我调了很久都没调出来,能否帮帮忙啊,加我QQ805854169
mmuuss586 发表于 2014-7-20 10:18 | 显示全部楼层
那你把程序,原理图贴上来看看,让大家帮你分析下;
xyz549040622 发表于 2014-7-20 11:54 | 显示全部楼层
1.找到官网推荐的电路,确保你的硬件连接正确
2.假如是自己写的程序,抓波形,确保和时序图一致,或者直接移植别人好的程序
3.假如波形正确,再返回硬件,查看芯片是否挂掉
 楼主| 流星在颤抖 发表于 2014-7-21 16:13 | 显示全部楼层
#include<msp430.h>
#include<DAC8760.h>
void DAC8760_delay(unsigned int j)
     while(j--)
       asm("NOP");
开始工作信号
void DAC8760_start()
// DAC8760_SCLK_0_();
DAC8760_LATCH_0_();
// DAC8760_delay(1);
// DAC8760_SCLK_1_();
DAC8760_LATCH_1_();
DAC8760_LATCH_0_();
// DAC8760_delay(3);
函数功能:
写数据
参数:
com
:前
位命令;
dat
:数据
void DAC8760_write_byte(unsigned char com, unsigned int dat)
unsigned char i=0;
DAC8760_LATCH_0_();
DAC8760_SCLK_0_();
for(i=0;i<8;i++)
  DAC8760_SCLK_0_();
  if(com&0x80)
   DAC8760_DIN_1_();
  else
   DAC8760_DIN_0_();
  delay_us(4);
  DAC8760_SCLK_1_();
  delay_us(4);
  com<<=1;
for(i=0;i<16;i++)
  DAC8760_SCLK_0_();
  if(dat&0x8000)
   DAC8760_DIN_1_();
  else
   DAC8760_DIN_0_();
  delay_us(4);
  DAC8760_SCLK_1_();
  delay_us(4);
  dat<<=1;
DAC8760_SCLK_1_();
//delay_us(3);
DAC8760_LATCH_1_();
DAC8760_DIN_1_();
//delay_us(3);
* 读字节
uint DAC8760_read_byte(unsigned char com, unsigned int dat)
uint data=0;
uchar i;
DAC8760_write_byte(com,dat);
DAC8760_LATCH_0_();
for(i=0;i<8;i++)
  DAC8760_SCLK_1_();
  //DAC8760_delay(2);
  DAC8760_SCLK_0_();
// DAC8760_delay(2);
for(i=0;i<16;i++)
  DAC8760_SCLK_1_();
  //DAC8760_delay(2);
  if(DAC8760_SDO_())
   data|=0x01;
  DAC8760_SCLK_0_();
  //DAC8760_delay(2);
  data<<=1;
return data;
连续写入
void DAC8760_con_write()
unsigned char i=0;
DAC8760_SCLK_0_();
DAC8760_LATCH_0_();
//DAC8760_delay(5);
for(i=0;i<24;i++)
  DAC8760_DIN_0_();
  DAC8760_SCLK_0_();
  DAC8760_SCLK_1_();
  //DAC8760_delay(1);
DAC8760_SCLK_0_();
DAC8760_LATCH_1_();
// DAC8760_delay(5);
void DA_init()
CLk_clear;
DAC8760_con_write();
    DAC8760_write_byte(DACResetReg,0x0001);
//  DAC8760_con_write();
     DAC8760_write_byte(DACConfigurationReg,0x0088);
//  while(DAC8760_read_byte(DACReadReg,ReadConfigurationReg)==0x0088);
   DAC8760_write_byte(DACControlReg,0x1006);
     DAC8760_write_byte(DACDataReg,0xffff);
// DAC8760_delay(10);
 楼主| 流星在颤抖 发表于 2014-7-21 16:20 | 显示全部楼层
2.假如是自己写的程序,抓波形,确保和时序图一致,或者直接 ...
电路附上了,程序也在那,有空帮忙研究下,没有仪器用啊。芯片刚换了一个也一样
mmuuss586 发表于 2014-7-21 18:49 | 显示全部楼层
电路附上了,程序也在那,有空帮忙研究下,没有仪器用啊。芯片刚换了一个也一样 ...
1、图没啥问题;
2、程序对了下时序也没看出问题;
ACControlReg:这个定义的多少啊?
有示波器的话,用示波器分析下看看吧;
 楼主| 流星在颤抖 发表于 2014-7-21 19:34 | 显示全部楼层
1、图没啥问题;
2、程序对了下时序也没看出问题;
0X55.。。。示波器有是有,太旧。观察不了。。哎,调了好几天了
hejianhu 发表于 2016-5-11 19:46 | 显示全部楼层
你好,你的DAC8760有输出吗?能参考一下程序吗?谢谢
