打开Psoc Creator出错
 楼主| gexingyouxian 发表于 2014-7-25 08:28 | 显示全部楼层 |阅读模式
Error: trn.M0004: There was a problem connecting to the external program CyMiniProg3Service.  Ensure that PSoC Programmer 3.10.1 or later is installed.  This may prevent the use of some communications devices.
应该怎么办呢
happygirlwz 发表于 2014-8-14 22:32 | 显示全部楼层
检查一下是不是MiniProg3驱动没有装好呀……
