[接口-信号链] BQ32000
 楼主| assange 发表于 2014-8-15 17:47 | 显示全部楼层 |阅读模式
大学第二年了,学了点模电数电的知识打算做个rtc时钟,测温测湿度,用BQ32000做rtc时钟,有没有人给我发个例程啊,准备用stm32来控制,谢谢
airwill 发表于 2014-8-16 06:57 | 显示全部楼层
这是个 I2C 接口的 RTC 时钟. 虽然寄存器有点多, 但并不复杂.
想要例程, 官方网站上有基于 TM4C 的, 去下载开发板的例程库吧
给你一份文档.
学生, 应该多自己动手.
 楼主| assange 发表于 2014-8-16 15:32 | 显示全部楼层
想要例程, 官方网站上有基于 TM4C 的, 去下载 ...
好的,我尽力去试试吧~:(
smilingangel 发表于 2014-8-20 22:55 | 显示全部楼层
先看看BQ32000是什么东东的吧。。。这个我还不是很清楚的啊。
smilingangel 发表于 2014-8-20 22:56 | 显示全部楼层
The bq32000 device is a compatible replacement for industry standard real-time clocks.
The bq32000 features an automatic backup supply with integrated trickle charger. The backup supply can be implemented using a capacitor or non-rechargeable battery. The bq32000 has a programmable calibration adjustment from –63 ppm to +126 ppm. The bq32000 registers include an OF (oscillator fail) flag indicating the status of the RTC oscillator, as well as a STOP bit that allows the host processor to disable the oscillator. The time registers are normally updated once per second, and all the registers are updated at the same time to prevent a timekeeping glitch. The bq32000 includes automatic leap-year compensation.
