c6000系列的C代码优化(五)
 楼主| huangfeng33 发表于 2014-10-11 19:10 | 显示全部楼层 |阅读模式
循环内部存在 if判断程序的优化
        1、源程序
for (k = 0; k < NB_PULSE; k++)
        i = codvec[k];
        j = sign;
        index = mult(i, Q15_1_5);
        track = sub(i, extract_l(L_shr(L_mult(index, 5), 1)));
        if (j > 0)
            if (i < l_subfr) code = add(code, 4096);
             codvec[k] += (2 * L_SUBFR);
        else
            if (i < l_subfr) code = sub(code, 4096);
            index = add(index, 16);
        if (indx[track] < 0)
            indx[track] = index;
        else
            if (((index ^ indx[track]) & 16) == 0)
                if (sub(indx[track], index) <= 0)
                    indx[track] = shl((indx[track] & 16), 3)
                   + shr(extract_l(L_mult((indx[track]&15), NB_POS)), 1) + (index & 15);
                else
                {   indx[track] = shl((index & 16), 3)
                   + shr(extract_l(L_mult((index & 15),NB_POS)), 1) + (indx[track] & 15);
            else
                if (sub((indx[track] & 15), (index & 15)) <= 0)
                else
                {   indx[track] = shl((indx[track] & 16), 3)
                    + shr(extract_l(L_mult((indx[track] & 15),NB_POS)), 1) + (index & 1
2、优化后的程序
       for (k = 0; k < 8; k++)
        i         = codvec[k];
        j         = sign;
        index           = _smpy(i, 6554)>>16;
        track         = i - index*5;
        con              = (j > 0);
                codvec[k]    = codvec[k] + 110*con;
                           index     = index + (!con)*16;
        conn      = (i < l_subfr);
        cono    = (j > 0)? 1:-1;
        code  = code + 4096*conn*cono;
                           n0   = index;
                           t0   = indx[track];
                           n1   = n0&16;
                           t1   = t0&16;
                           n2   = n0&15;
                           t2   = t0&15;
        tmp0    = (_sshl(n1,19)>>16) + n2*NB_POS + t2;
        tmp1    = (_sshl(t1,19)>>16) + t2*NB_POS + n2;
        conp    = (((n1 == t1)&&(t0 > n0))||((n1 != t1)&&(t2 <= n2)));
                           tmp   = conp*tmp0 + (!conp)*tmp1;
        if (t0 < 0)
            indx[track] = n0;
        else
            indx[track] = tmp;
  3、优化说明
        源程序中在循环中含有许多的 if 结构,在优化时对 if 结构首先进行化简,再将化简后的 if结构用条件运算表达式进行改写,最后使循环可以 Pipeline。
 楼主| huangfeng33 发表于 2014-10-11 19:11 | 显示全部楼层
九、 少量中值问题的优化
        1、源程序
for (i = 0; i < n; i++)
            max = -32767;
            for (j = 0; j < n; j++)
                    if (sub (tmp2[j], max) >= 0)
                                max = tmp2[j];
                                ix = j;
                     tmp2[ix] = -32768;
                     tmp = ix;
            max = -32767;
                                max = tmp2[j];
                                ix = j;
                     tmp2[ix] = -32768;
                     tmp = ix;
if (n0>n1) {temp=n0;n0=n1;n1=temp;}
       if (n1>n2) {temp=n1;n1=n2;n2=temp;}
       if (n2>n3) {temp=n2;n2=n3;n3=temp;}
       if (n3>n4) {temp=n3;n3=n4;n4=temp;}
       if (n1>n2) {return n1;}
  3、优化说明
        源程序也为一个求中值的问题,由于已知循环次数固定为 5,因此将循环展开使用 if语句直接求取中值。
 楼主| huangfeng33 发表于 2014-10-11 19:12 | 显示全部楼层
十、 位操作优化
        1、源程序
static Word16 Bin2int (Word16 no_of_bits,    Word16 *bitstream)
    Word16 value, i, bit;
    value = 0;
        for (i = 0; i < no_of_bits; i++)
        value = shl (value, 1);
        bit = *bitstream++;
        if (sub (bit, BIT_1) == 0)
        value = add (value, 1);
    return (value);
        for (i = 0; i < prmno[mode]; i++)
        prm = Bin2int (bitno[mode], bits);
        bits += bitno[mode];
2、优化后的程序
value = 0;
    bitsp = bits;
    bitnop= &bitno[mode][0];
    j  = *bitnop++;
    j1 = *bitnop++;
    j2 = *bitnop++;
    j3 = *bitnop++;
    j4 = *bitnop++;
    _nassert(loop[mode]>=35);
        for (i = 0; i < loop[mode]; i++)
        value = value*2 + *bitsp++;
        j--;
        if (j == 0)
           *prm++ = value;
           value = 0;
           j  = j1;
           j1 = j2;
           j2 = j3;
           j3 = j4;
           j4 = *bitnop++;
   3、优化说明
        源程序按照数据位流定义取出参数,为双重循环结构,优化中采用重新根据位流的 bit长度定义循环次数,化简为单重循环,然后优化循环,去除 boundary,使 pipeline 的数目最小。
