/* This is an example for EMIF of C5509 */
#include <csl.h>
#include <csl_pll.h>
#include <csl_emif.h>
#include <csl_chip.h>
/* Uint16 x; */
/* Uint32 y; */
CSLBool b;
unsigned int datacount = 0;
int databuffer[1000] ={0};
int *souraddr,*deminaddr;
/*锁相环的设置*/
PLL_Config myConfig = {
0, //IAI: the PLL locks using the same process that was underway
//before the idle mode was entered
1, //IOB: If the PLL indicates a break in the phase lock,
//it switches to its bypass mode and restarts the PLL phase-locking
//sequence
24, //PLL multiply value; multiply 24 times
1 //Divide by 2 PLL divide value; it can be either PLL divide value
//(when PLL is enabled), or Bypass-mode divide value
//(PLL in bypass mode, if PLL multiply value is set to 1) CPU frequency = 144 MHz
/*SDRAM的EMIF设置*/
EMIF_Config emiffig = {
0x221, //EGCR : the MEMFREQ = 001,the clock for the memory is 1/2 to cpu frequence
// the WPE = 0 ,forbiden the writing posting when we debug the EMIF
// the MEMCEN = 1,the memory clock is reflected on the CLKMEM pin
// the NOHOLD = 1,HOLD requests are not recognized by the EMIF
0xFFFF, //EMI_RST: any write to this register resets the EMIF state machine
0x3FFF, //CE0_1: CE0 space control register 1
// MTYPE = 011,Synchronous DRAM(SDRAM),16-bit data bus width
0xFFFF, //CE0_2: CE0 space control register 2
0x00FF, //CE0_3: CE0 space control register 3
// TIMEOUT = 0xFF;
0x7FFF, //CE1_1: CE1 space control register 1
0xFFFF, //CE1_2: CE1 space control register 2
0x00FF, //CE1_3: CE1 space control register 3
0x7FFF, //CE2_1: CE2 space control register 1
0xFFFF, //CE2_2: CE2 space control register 2
0x00FF, //CE2_3: CE2 space control register 3
0x7FFF, //CE3_1: CE3 space control register 1
0xFFFF, //CE3_2: CE3 space control register 2
0x00FF, //CE3_3: CE3 space control register 3
0x2911, //SDC1: SDRAM control register 1
// TRC = 8
// SDSIZE = 0;SDWID = 0
// RFEN = 1
// TRCD = 2
// TRP = 2
0x0410, //SDPER : SDRAM period register
// 7ns *4096
0x07FF, //SDINIT: SDRAM initialization register
// any write to this register to init the all CE spaces,
// do it after hardware reset or power up the C55x device
0x0131 //SDC2: SDRAM control register 2
// SDACC = 0;
// TMRD = 01;
// TRAS = 0101;
// TACTV2ACTV = 0001;
main()
/*初始化CSL库*/
CSL_init();
/*EMIF为全EMIF接口*/
CHIP_RSET(XBSR,0x0a01);
/*设置系统的运行速度为144MHz*/
PLL_config(&myConfig);
/*初始化DSP的外部SDRAM*/
EMIF_config(&emiffig);
上述程序是外部存储器接口的SDRAM实验中,配置SDRAM的EMIF接口程序。
在TMS320VC5509的EMIF手册中提到
1、在这个程序中,CPU频率为144MHz,MEMFREQ=001b,那从哪配置EBSR中的EMIFX2 bit?
2、main函数中,EMIF为全EMIF接口, CHIP_RSET(XBSR,0x0a01); XBSR这个寄存器中的各个位的含义是什么?没找到有关这个寄存器的介绍啊?
