[STM32F4] STM32F4 USB HOST HID
 楼主| cws4 发表于 2014-11-18 23:05 | 显示全部楼层 |阅读模式
我有一个设备通过USB进行通信,电脑上位机和设备通信的过程通过Bus Hound 捕捉如下:
Device - Device ID (followed by the endpoint for USB devices)
            (3) 英特尔(R) USB 3.0 可扩展主机控制器
            (20) USB 输入设备
            (21) HID-compliant device
  Length - Total transfer length
  Phase  - Phase Type
            CTL   USB control transfer
            IN    Data in transfer
            OUT   Data out transfer
            USTS  USB status
  Data   - Hex dump of the data transferred
  Descr  - Description of the phase
  Cmd... - Position in the captured data
Device  Length    Phase  Data        Description                       Cmd.Phase.Ofs(rep)
------  --------  -----  -------------------- ------------------------------USB设备驱动枚举识别--------------------------------------------------  --------------------------------  ------------------
  20.0            CTL    80 06 00 01          00 00 12 00        GET DESCRIPTOR                           1.1.0
  20.0        18  IN     12 01 00 00          00 00 00 20          89 0f 16 01      00 00 00 00          00 00                                               ....... ..........                       1.2.0
  20.0            CTL    80 06 00 02  00 00 09 00        GET DESCRIPTOR                           2.1.0
  20.0         9  IN     09 02 29 00  01 01 00 80  fa        ..)......                                2.2.0
  20.0            CTL    80 06 00 02  00 00 29 00        GET DESCRIPTOR                           3.1.0
  20.0        41  IN     09 02 29 00  01 01 00 80  fa     09 04 00  00 02 03 00  00 00  09 21  00 01 21 01  22 1d 00  07  05 81 03 08  ..)................!..!.".......         3.2.0
        (03端点描述符中断传输)
  20.0            CTL    00 09 01 00  00 00 00 00        SET CONFIG                               4.1.0
  20.0            CTL    21 0a 00 00  00 00 00 00        SET IDLE                                 5.1.0
  20.0            USTS   c0000004        stall pid                                5.2.0
  20.0            CTL    81 06 00 22  00 00 5d 00        GET DESCRIPTOR                           6.1.0
  20.0        29  IN     06 00   ff 09  01 a1   01 09   01 95      08 75           08 15          00 26    ff 00   81 02    09 02   95 5f        75 08     91 02    c0          ...........u...&......._u....            6.2.0
  20           0  IN
  -------------------------------------------------------------------------------USB上位机连接--------------------------------------------------------------------------------------------------------
        7.1.0(3323)
  20.0               CTL    80 06 00 03  09 04 80 00        GET DESCRIPTOR                        3330.1.0
  20.0         4    IN      04 03 09 04        ....                                  3330.2.0
  20.0              CTL    80 06 00 03  09 04 80 00        GET DESCRIPTOR                        3331.1.0
  20           0     IN        3332.1.0
  20.0         4    IN     04 03 09 04        ....                                  3331.2.0
  20.0              CTL    80 06 00 03  09 04 80 00        GET DESCRIPTOR                        3333.1.0
  20.0         4    IN       04 03 09 04        ....                                  3333.2.0
  20           0    IN        3334.1.0
  20.2        95  OUT    ab 86 01 01  01 01 01 01  31 68 00 00  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  ........1h......................      3335.1.0
  21           96  OUT    00 ab 86 01  01 01 01 01  01 31 68 00  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  .........1h.....................      3336.1.0
  20           0    IN        3337.1.0
  20.1         8  IN     ab 86 01 01  01 01 01 01        ........                              3338.1.0
  21           9   IN     00 ab 86 01  01 01 01 01  01        .........                             3339.1.0
  20           0   IN        3340.1.0(8488)
  -----------------------------------------------------------------------------USB上位机发送数据------------------------------------------------------------------------------------------------------
  20.2        95  OUT    ab c1 01 00  01 07 01 00  31 32 33 34  95 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  ........1234....................     11828.1.0
  21          96  OUT    00 ab c1 01  00 01 07 01  00 31 32 33  34 95 00 00  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  .........1234...................     11829.1.0
  20           0  IN        11830.1.0(6008)
我用STM32F4Discover板子作为主机,在STM32F4识别鼠标程序的基础上修改,这个设备可以枚举成功,枚举成功后,要先输出数据给从机,连接设备,这个数据该怎么发出去?
发数据后如何接受返回的数据。高手路过请指导。
LOVE_ELEC 发表于 2014-11-19 11:28 | 显示全部楼层
根据配置描述符中设定的Polling Interval(发送IN Token的间隔时间),进行IN Token的循环发送,并在间隔时间内监测Device是否有数据反馈。具体实现可以参考官方Demo。若楼主用的是官方V2.1.0的USB库,可以参考usbd_hid_core.c文件中的USBH_HID_Handle函数。希望能够帮到楼主!
