[STM32] 大侠来帮我看下这个定时器对外部脉冲计数的程序有什么问题
 楼主| 大虾快来 发表于 2014-11-23 17:47 | 显示全部楼层 |阅读模式
程序实现的功能:对PA0接受的脉冲信号计数,用USART将的到的计数值发送串口助手显示
  1. void RCC_Configuration(void)
  3.   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);        //GPIOA时钟打开
  4.   RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2,ENABLE);        //使能USART2的时钟
  5. }
  6. void PortInit(void)
  7. {
  8.   GPIO_InitTypeDef GPIO_InitStructure;
  9.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  10.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;     //复用推挽输出
  11.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  12.   GPIO_Init(GPIOA,&GPIO_InitStructure);
  13.   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
  14.   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //
  15.   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //50M时钟速度
  16.   GPIO_Init(GPIOA, &GPIO_InitStructure);
  17. }
  18. void USART_Configuration(void)
  19. {
  20.   USART_InitTypeDef USART_InitStructure;
  21.   USART_InitStructure.USART_BaudRate=9600;    //设置串口通信时的波特率为9600
  22.   USART_InitStructure.USART_WordLength=USART_WordLength_8b;  //设置数据位长度8个位
  23.   USART_InitStructure.USART_StopBits=USART_StopBits_1;   //在帧结尾传输1个停止位
  24.   USART_InitStructure.USART_Parity=USART_Parity_No;   //设置校验位“无”
  25.   //设置硬件控制流失能
  26.   USART_InitStructure.USART_HardwareFlowControl=USART_HardwareFlowControl_None;
  27.   USART_InitStructure.USART_Mode=USART_Mode_Rx|USART_Mode_Tx;//设置发送和接收使能
  28.
  29.   USART_Init(USART2,&USART_InitStructure);
  30.   USART_Cmd(USART2,ENABLE);//开启USART2
  31. }
  32. void TIM2_Configuration(void) //只用一个外部脉冲端口
  33. {
  34. TIM_TimeBaseInitTypeDef   TIM_TimeBaseStructure;
  35.    //配置TIMER2作为计数器
  36.    TIM_DeInit(TIM2);
  37.    TIM_TimeBaseStructure.TIM_Period = 0xFFFF;
  38. TIM_TimeBaseStructure.TIM_Prescaler = 0x00;
  39. TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
  40. TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  41. TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure); // Time base configuration
  42. TIM_ETRClockMode2Config(TIM2, TIM_ExtTRGPSC_OFF, TIM_ExtTRGPolarity_NonInverted, 0);
  43. TIM_SetCounter(TIM2, 0);
  44. TIM_Cmd(TIM2, ENABLE);
  45. }
  46. u8 SendTemp[] = ":00";
  47. u8 i,j;
  48. u8 COUN2=0;
  49. /*************主函数**************************/
  50. int main(void)
  51. {
  52.   Init_SysTick();  //SysTick时钟初始化
  53.   RCC_Configuration();         //端口时钟初始化
  54.   PortInit();                         //端口初始化
  55.   USART_Configuration();  //串口初始化
  56.   TIM2_Configuration();
  57.   j = sizeof(SendTemp);  //提取字节数
  58.   while(1)
  59.    {
  60.    COUN2=TIM2->CNT;
  61.    SendTemp[1]=COUN2/10;
  62.    SendTemp[2]=COUN2%10;
  63.     for(i=0;i<j;i++)
  64.         {
  65.           //j = sizeof(SendTemp);  //提取字节数
  66.       USART_SendData(USART2,SendTemp[i]);//发送一位数据
  67.           while(USART_GetFlagStatus(USART2,USART_FLAG_TXE)==RESET);//判断是否发送完毕
  68.         }
  69.         delay_ms(50);  //延时50ms
  70.    }
  71. }
wangch_sh 发表于 2014-11-23 19:34 | 显示全部楼层
你应该把现象说一下,才好分析。
 楼主| 大虾快来 发表于 2014-11-23 20:08 | 显示全部楼层
你应该把现象说一下,才好分析。
串口助手只显示数组的Temp【0】,不显示temp【1】和Temp【2】,就是这样,搞到我好困惑啊
