[Atmel] XMEGA-A1 Xplain development kit
 楼主| ddllxxrr 发表于 2014-12-3 21:55 | 显示全部楼层 |阅读模式
XMEGA-A1 Xplain development kit provides a straightforward way to development of applications with Atmel XMEGA microcontrollers.
XMEGA a family of powerful 8/16-bit RISC microcontrollers with many built-in peripherials (DMA, RTC, LCD driver, 12 bit ADC,…) is ideally suited for relatively high performance applications, where we will with favor use its features – often without a need to add any other peripherials.
In order to get easily familiar with AVR XMEGA family features, ATMEL also produces fevelopment/ evaluation kits for these processors. From several types available, in our offer you can find on stock the XMEGA-A1 Xplain with the ATxmega128A1 processor. The development kit enables development and testing of applications including usage of ADC, DAC and I/O ports. The kit is power-supplied via a USB port, that´s why you can supply it from a PC but even from an external AC adapter with an USB connector output. A detailed description can be found in theXplained user guide, Xplained getting started and Xmega basics training documents.
On the Atmel website you can find many documents about various processor´s parts and its usage in the concrete applications.
2404
