This file contains any messages produced by compilers while running configure, to aid debugging if configure makes a mistake. It was created by GStreamer Good Plug-ins configure 0.10.30, which was generated by GNU Autoconf 2.68. Invocation command line was $ ./configure --prefix=/usr --host=arm-linux --build=i686-pc-linux-gnu --without-check --disable-speex --disable-shout2test --disable-shout2 --disable-dv1394 --disable-libpng --disable-libdv --disable-libcaca --disable-ladspa --disable-jpeg --disable-flac --disable-esd --disable-esdtest --disable-cairo --disable-aalib --disable-aalibtest --disable-x --disable-xvideo --disable-hal NM=nm ## --------- ## ## Platform. ## ## --------- ## hostname = ubuntu-yfb uname -m = i686 uname -r = 3.13.0-40-generic uname -s = Linux uname -v = #69-Ubuntu SMP Thu Nov 13 17:56:26 UTC 2014 /usr/bin/uname -p = unknown /bin/uname -X = unknown /bin/arch = unknown /usr/bin/arch -k = unknown /usr/convex/getsysinfo = unknown /usr/bin/hostinfo = unknown /bin/machine = unknown /usr/bin/oslevel = unknown /bin/universe = unknown PATH: /home/shkj-kelly/ltib/bin PATH: /opt/freescale/ltib/usr/spoof PATH: /home/shkj-kelly/ltib/bin PATH: /opt/freescale/ltib/usr/bin PATH: /opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin PATH: /usr/local/bin PATH: /usr/bin PATH: /bin PATH: /usr/bin/X11 PATH: /usr/X11R6/bin ## ----------- ## ## Core tests. ## ## ----------- ## configure:3591: checking for a BSD-compatible install configure:3659: result: /usr/bin/install -c configure:3670: checking whether build environment is sane configure:3720: result: yes configure:3769: checking for arm-linux-strip configure:3785: found /opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-linux-strip configure:3796: result: arm-linux-strip configure:3861: checking for a thread-safe mkdir -p configure:3900: result: /bin/mkdir -p configure:3913: checking for gawk configure:3943: result: no configure:3913: checking for mawk configure:3929: found /usr/bin/mawk configure:3940: result: mawk configure:3951: checking whether make sets $(MAKE) configure:3973: result: yes configure:4065: checking nano version configure:4071: result: 0 (release) configure:4097: checking whether to enable maintainer-specific portions of Makefiles configure:4106: result: no configure:4124: checking build system type configure:4138: result: i686-pc-linux-gnu configure:4158: checking host system type configure:4171: result: arm-unknown-linux-gnu configure:4567: checking how to print strings configure:4594: result: printf configure:4627: checking for style of include used by make configure:4655: result: GNU configure:4685: checking for arm-linux-gcc configure:4712: result: gcc configure:4981: checking for C compiler version configure:4990: gcc --version >&5 arm-none-linux-gnueabi-gcc (Freescale MAD -- Linaro 2011.07 -- Built at 2011/08/10 09:20) 4.6.2 20110630 (prerelease) Copyright (C) 2011 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. configure:5001: $? = 0 configure:4990: gcc -v >&5 Using built-in specs. COLLECT_GCC=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/arm-none-linux-gnueabi-gcc COLLECT_LTO_WRAPPER=/opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/../libexec/gcc/arm-fsl-linux-gnueabi/4.6.2/lto-wrapper Target: arm-fsl-linux-gnueabi Configured with: /work/build/.build/src/gcc-linaro-4.6-2011.06-0/configure --build=i686-build_pc-linux-gnu --host=i686-build_pc-linux-gnu --target=arm-fsl-linux-gnueabi --prefix=/work/fsl-linaro-toolchain-2.13 --with-sysroot=/work/fsl-linaro-toolchain-2.13/arm-fsl-linux-gnueabi/multi-libs --enable-languages=c,c++ --with-pkgversion='Freescale MAD -- Linaro 2011.07 -- Built at 2011/08/10 09:20' --enable-__cxa_atexit --disable-libmudflap --disable-libgomp --disable-libssp --with-gmp=/work/build/.build/arm-fsl-linux-gnueabi/build/static --with-mpfr=/work/build/.build/arm-fsl-linux-gnueabi/build/static --with-mpc=/work/build/.build/arm-fsl-linux-gnueabi/build/static --with-ppl=/work/build/.build/arm-fsl-linux-gnueabi/build/static --with-cloog=/work/build/.build/arm-fsl-linux-gnueabi/build/static --with-libelf=/work/build/.build/arm-fsl-linux-gnueabi/build/static --with-host-libstdcxx='-static-libgcc -Wl,-Bstatic,-lstdc++,-Bdynamic -lm -L/work/build/.build/arm-fsl-linux-gnueabi/build/static/lib -lpwl' --enable-threads=posix --enable-target-optspace --enable-plugin --enable-multilib --with-local-prefix=/work/fsl-linaro-toolchain-2.13/arm-fsl-linux-gnueabi/multi-libs --disable-nls --enable-c99 --enable-long-long --with-system-zlib Thread model: posix gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 -- Built at 2011/08/10 09:20) configure:5001: $? = 0 configure:4990: gcc -V >&5 arm-none-linux-gnueabi-gcc: error: unrecognized option '-V' configure:5001: $? = 1 configure:4990: gcc -qversion >&5 arm-none-linux-gnueabi-gcc: error: unrecognized option '-qversion' configure:5001: $? = 1 configure:5021: checking whether the C compiler works configure:5043: gcc conftest.c -lcairo >&5 /opt/freescale/usr/local/gcc-4.6.2-glibc-2.13-linaro-multilib-2011.12/fsl-linaro-toolchain/bin/../lib/gcc/arm-fsl-linux-gnueabi/4.6.2/../../../../arm-fsl-linux-gnueabi/bin/ld: cannot find -lcairo collect2: ld returned 1 exit status configure:5047: $? = 1 configure:5085: result: no configure: failed program was: | /* confdefs.h */ | #define PACKAGE_NAME "GStreamer Good Plug-ins" | #define PACKAGE_TARNAME "gst-plugins-good" | #define PACKAGE_VERSION "0.10.30" | #define PACKAGE_STRING "GStreamer Good Plug-ins 0.10.30" | #define PACKAGE_BUGREPORT "bugzilla.gnome.org/enter_bug.cgi?product=GStreamer" | #define PACKAGE_URL "" | #define PACKAGE "gst-plugins-good" | #define VERSION "0.10.30" | /* end confdefs.h. */ | | int | main () | { | | ; | return 0; | } configure:5090: error: in `/home/shkj-kelly/ltib/rpm/BUILD/gst-plugins-good-0.10.30': configure:5092: error: C compiler cannot create executables See `config.log' for more details
收藏0 举报
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
人才类勋章
时间类勋章
发帖类勋章
等级类勋章
扫码关注 21ic 官方微信
扫码关注嵌入式微处理器
扫码关注电源系统设计
扫码关注21ic项目外包
扫码浏览21ic手机版
本站介绍 | 申请友情链接 | 欢迎投稿 | 隐私声明 | 广告业务 | 网站地图 | 联系我们 | 诚聘英才
京公网安备 11010802024343号
