- void main()
- CLK_SYSCLKSourceSwitchCmd(ENABLE);
- CLK_SYSCLKSourceConfig(CLK_SYSCLKSource_HSI);
- CLK_SYSCLKDivConfig(CLK_SYSCLKDiv_16);
- Uart1_Init();
- enableInterrupts(); //开启总中断
- printf("11");
- while(1)
- UART1_printf("hello");
- delay2(500);
- void Uart1_Init(void)
- // CLK_PeripheralClockConfig(CLK_Peripheral_USART1, ENABLE);
- USART_DeInit(USART1); /* 将寄存器的值复位 */
- * 将UART1配置为:
- * 波特率 = 115200
- * 数据位 = 8
- * 1位停止位
- * 无校验位
- * 使能接收和发送
- * 使能接收中断
- USART_Init(USART1,(u32)115200, USART_WordLength_8b,USART_StopBits_1,USART_Parity_No,(USART_Mode_TypeDef)(USART_Mode_Tx|USART_Mode_Tx));
- // USART1->CR2|=(1<<2);
- // USART1->CR2|=(1<<3);
- // USART1->CR1|=(1<<5);
- USART_ITConfig(USART1,(USART_IT_TypeDef)(USART_IT_RXNE|USART_IT_OR),ENABLE);
- USART_Cmd(USART1,ENABLE);
- }[code]
- INTERRUPT_HANDLER(USART1_RX_TIM5_CC_IRQHandler, 28)
- u8 Res;
- /* 读取接收到的数据,当读完数据后自动取消RXNE的中断标志位 */
- Res =USART_ReceiveData8(USART1);
- /* 将读取的字符发送到PC */
- USART_SendData8(USART1,Res);
- /* In order to detect unexpected events during development,
- it is recommended to set a breakpoint on the following instruction.
[/code]
