[AVR单片机] avr驱动l298n带动直流电机
 楼主| 还好还好1 发表于 2015-2-5 09:30 | 显示全部楼层 |阅读模式
用avr输出驱动l298n再驱动直流两个直流电机。可是编程总是出现错误,真的不太明白呀
#include <avr/io.h>
#include <avr/wdt.h>
//#include <util/delay.h>
#include <avr/interrupt.h>
#define Robot_Enable { PORTA |=(1<<PA5)}         //电机使能
#define Robor_Disable { PORTA &=~(1<<PA5)}      //电机禁止
#define D0 PORTA.0
#define D1 PORTA.1
#define D2 PORTA.2
#define D3 PORTA.3
void motor_ctl(void)                           //电机控制程序
  if (PORTC.0==1)                              //向前
    D0=1;
    D1=0;
    D2=1;
    D3=0;
  else if (PORTC.1==1)                          //向后
    D0=0;
    D1=1;
    D2=0;
    D3=1;
  else if (PORTC.2==1)                         //向左
    D0=0;
    D1=1;
    D2=1;
    D3=0;
  else if (PORTC.3==1)                         //向右
    D0=1;
    D1=0;
    D2=0;
    D3=1;
  void port_init(void)                         //端口初始化
     DDRA=0xFF;
     PORTA=0xFF;
  int main()
    port_init();
        while(1)
           motor_ctl();
        return 0;
出现错误../a.c:16: error: expected ')' before numeric constant
../a.c:18: error: expected ';' before numeric constant
../a.c:19: error: expected ';' before numeric constant
../a.c:20: error: expected ';' before numeric constant
../a.c:21: error: expected ';' before numeric constant
../a.c:23: error: expected ')' before numeric constant
../a.c:25: error: expected ';' before numeric constant
../a.c:26: error: expected ';' before numeric constant
../a.c:27: error: expected ';' before numeric constant
../a.c:28: error: expected ';' before numeric constant
../a.c:30: error: expected ')' before numeric constant
../a.c:32: error: expected ';' before numeric constant
../a.c:33: error: expected ';' before numeric constant
../a.c:34: error: expected ';' before numeric constant
../a.c:35: error: expected ';' before numeric constant
../a.c:37: error: expected ')' before numeric constant
../a.c:39: error: expected ';' before numeric constant
../a.c:40: error: expected ';' before numeric constant
../a.c:41: error: expected ';' before numeric constant
../a.c:42: error: expected ';' before numeric constant
ningling_21 发表于 2015-2-5 17:16 | 显示全部楼层
注意,有些编译器不支持 PORTC.1 这样的写法
lgj3118 发表于 2015-2-8 15:05 | 显示全部楼层
看看学习学习
一颗心的思考 发表于 2015-2-8 20:09 | 显示全部楼层
PORTC.0==1?不应该是PINC.0==1?
一颗心的思考 发表于 2015-2-8 20:10 | 显示全部楼层
main函数是不是多了个括号啊
s17701332 发表于 2015-2-9 21:08 | 显示全部楼层
好像是编译器不支持PORTD.0这样的位操作,然后main怎么在motor_ctl函数里面?
 楼主| 还好还好1 发表于 2015-3-23 13:48 | 显示全部楼层
恩,已经修改过来了
