[Atmel] Arduino Zero Targets the IoT
 楼主| ddllxxrr 发表于 2015-2-8 16:16 | 显示全部楼层 |阅读模式
A new development board has been released from the Arduino –
Arduino Zero
A new development board has been released from the Arduino stable of development products. This board has been developed jointly by Atmel and Arduino and targets ‘The next generation of IoT development’.
The Zero board contains an Atmel SAMD21 microcontroller, built around the 32-bit ARM Cortex M0+ processor. The board also packs 256 KB of flash and 32 KB of SRAM. Shield connectors are Arduino R3 compatible at 3.3 V. The (EDBG) Atmel embedded software debugger is available to aid program development.
Acording to Massimo Banzi, co-founder and CEO at Arduino “The Zero board expands the Arduino family by providing increased performance to fuel creativity of the Maker community. The flexible feature set enables endless project opportunities for devices and acts as a great educational tool for learning about 32-bit application development”.
2403
2403
