[资料分享与下载] 飞思卡尔单片机DZ60---SCI(中断发送)
niuyaliang 发表于 2015-2-27 20:08 | 显示全部楼层 |阅读模式
  1. [cpp] view plaincopy
  2. #include <hidef.h> /* for EnableInterrupts macro */
  3. #include "derivative.h" /* include peripheral declarations */
  4.
  5.
  6. #define LED_D1      PTDD_PTDD0
  7. #define LED_D1_DIR  PTDDD_PTDDD0
  8.
  9. #define LED_ON      0
  10. #define LED_OFF     1
  11.
  12. unsigned char SCANF_SEND_STRINGS[] = "HELLO MCU WORLD";
  13. unsigned char *pSendString = SCANF_SEND_STRINGS;
  14.
  15. /*************************************************************/
  16. /*                  初始化总线时钟PEE模式                    */
  17. /*              外部晶振频率为4MHz,总线频率16MHz            */
  18. /*************************************************************/
  19. void INIT_MCG(void)
  20. {
  21.   MCGC2=0x36;
  22.   while(!MCGSC_OSCINIT);
  23.   MCGC1=0xb8;
  24.   while(MCGSC_IREFST);
  25.   while(MCGSC_CLKST!=0b10);
  26.   MCGC2_LP = 1;
  27.   MCGC1 = 0x90;
  28.   MCGC3 = 0x48;
  29.   MCGC2_LP = 0;
  30.   while(!MCGSC_PLLST);
  31.   while(!MCGSC_LOCK);
  32.   MCGC1 = 0x10;
  33.   while(MCGSC_CLKST!=0b11);
  34. }
  35.
  36.
  37.
  38.
  39.
  40. void delay(void)
  41. {
  42.   unsigned int i;
  43.   unsigned int j;
  44.
  45.
  46.   for(i = 0; i < 100; i++)
  47.      for(j = 0; j < 4000; j++);
  48.
  49. }
  50.
  51.
  52. void main(void) {
  53.
  54.   DisableInterrupts;
  55.   SOPT1 = 0;
  56.   INIT_MCG();
  57.   EnableInterrupts; /* enable interrupts */
  58.   /* include your code here */
  59.
  60.   LED_D1_DIR = 1;
  61.   LED_D1     = LED_OFF;
  62.
  63.
  64.
  65. //以下为设置波特率,以及初始化SCI1控制寄存器
  66.   SCI1BDH = 0X00;
  67.   SCI1BDL = 0X68;//波特率设置为9600
  68.   SCI1C1 = 0x00; //设置SCI1为正常模式,八位数据位,无奇偶校验
  69.   SCI1C2 = 0x88; //TIE = 1(bit7) 启动TDRE中断,发送中断使能
  70.                  //手册指出,如果设置了发送中断使能TIE位,每当TDRE = 1时都请求硬件中断
  71.                  //TE  = 1(bit3) 发送器打开
  72.   while(1);
  73.
  74.   for(;;) {
  75.     __RESET_WATCHDOG(); /* feeds the dog */
  76.   } /* loop forever */
  77.   /* please make sure that you never leave main */
  78. }
  79.
  80.
  81. /*************************************************************/
  82. /*                SCI1中断向量函数                           */
  83. /*                向量编号为18,中断来源TDRE,TC              */
  84. /*************************************************************/
  85. interrupt 18 void SCI1_SEND(void)
  86. {
  87.   while(*pSendString != '\0')
  88.   {
  89.     while(!SCI1S1_TDRE);
  90.     SCI1D = *pSendString;
  91.     pSendString++;
  92.     LED_D1 = ~ LED_D1;
  93. //    delay();
  94.   }
  95.
  96. }
quray1985 发表于 2015-2-28 10:32 来自手机 | 显示全部楼层
谢谢分享
powerful1 发表于 2015-2-28 13:49 | 显示全部楼层
恩,谢谢楼主分享
